Cross-Platform Project Sharing?
I've got two Windows purist buddies who are buying DP for Windows. Too excited to wait for the answer to this question:
Can I just copy a project's files to a HD and the Windows DP will open it up as is (sans any 3rd party plugs I've used)?
Or are there hurdles to jump through to share projects across platforms?
Thanks in Advance!
Thanks in Advance!
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
Re: Cross-Platform Project Sharing?
AFAIK the DP documents are readable by either platform regardless of the platform. One might have to be careful about plugs and VIs. I don't know, but I suspect that the same plugs in Windows might not be exactly the same as on a Mac. The audio format should be fine but I'd certainly stick to bwav as the format.
Thanks MLC.MIDI Life Crisis wrote:AFAIK the DP documents are readable by either platform regardless of the platform. One might have to be careful about plugs and VIs. I don't know, but I suspect that the same plugs in Windows might not be exactly the same as on a Mac. The audio format should be fine but I'd certainly stick to bwav as the format.
If I'm the first to try this (within the week, perhaps?) I'll post my findings.
-Todzilla
Do report back. I don't know anyone working music or sound on a Windows machine so won't have an opportunity to try this, but I am considering a Windows laptop now that both Finale and DP are PC friendly. In the end I'll probably cave and get another Macbook Pro but the lure of a cheap and somewhat "disposable" laptop also has a bit if an attraction and cross platform compatibility would then become very important.
What would be great is 100% compatibility with Pro Tools... but that would just be delusional.
- Radiogal
Answere is YES. i tried it out with a smaller try out project from PC to Mac and reversed. It´s plane and simple
BTW Even Andys AMPGUI will work on Windows!!
That's super great news, Radiogal. Thanks!Radiogal wrote:Answere is YES. i tried it out with a smaller try out project from PC to Mac and reversed. It´s plane and simple
-Todzilla
