Update 1.1.1 is out
Update 1.1.1 is out
Anyone tried the 1.1.1 update? Version 1.1 "crash almost all the time" bug fixed?
Haven't tried it, but many thanx for the tip-off.
Downloading now. Will report!
**edit**
Ok, seems to work fine in DP 4.61. Thanks MOTU for sorting it out.
**edit**
Macbook, Leopard 10.5.1, Logic 8.01, MOTU Traveler.
http://www.smoothbeatsonly.com
version 1.1.1
The prevoous versions never worked.
This (1.1.1) works fine except for notes that stick if stop in mid playback.
Re: version 1.1.1
In this case the culprit is not SI but DP I'm afraid. For me , this problem appeared with 4.6, I thought 4.61 would fix but no, and that's very annoying.ittango wrote:The prevoous versions never worked.
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
Problems Loading the MSI.dat file
I'm on a mac using 10.4.4
For installing I copied the big dat file from the DVD to my desktop then installed the program from the CD
But when I load it as a plug-in in Digital performer all the settings are empty because it isn't loading the dat file. I installed the update and the dat file also does not load when I open MSI as a stand alone program. I've tryed moving the dat file right into the main folder, replacing the MSI.dat shortcut with the file itself and still, no dice.
ANyone have any idea of what is wrong? I'm sure it's something simple but I just can't figure it out
thanks!
thanks!
