Stem mixes from DP 11 to Antelope Orion Studio
ejv
Post by ejv »
I cannot seem to figure out how to send stem mixes from DP to my Antelope Orion Studio interface. I can see the interface in DP audio MIDI setup but can't direct the outputs to the Antelope from DP. Are they not directed there by the Thunderbolt connection? I see the 30 DP outputs plus the 32 busses and thats it. Am I supposed to have the interfaces daisy chained? Thanks for your response.
Re: Stem mixes from DP 11 to Antelope Orion Studio
ejv wrote: Sun Apr 27, 2025 2:49 pm I cannot seem to figure out how to send stem mixes from DP to my Antelope Orion Studio interface. I can see the interface in DP audio MIDI setup but can't direct the outputs to the Antelope from DP. Are they not directed there by the Thunderbolt connection? I see the 30 DP outputs plus the 32 busses and thats it. Am I supposed to have the interfaces daisy chained? Thanks for your response.
Not how it works. Other than that, there's not enough information here to answer your question.
On a Mac, you must grant DP access to the Microphone in System Preferences/Settings/Security depending on your macOS — this is an Apple requirement but is no longer granted automatically. Without that, nothing else can happen.
From DP, you must be able to select your interface from Setup/Configure Audio System/Configure Hardware Driver/(select your interface)
You need an understanding of the many I/O options available to you in DP plus those available in your interface as enabled by its drivers.
How you set it all up from there depends on your goal. Real time for live performance is way different than sending AV stems for post production etc. — none of which we know.
First, know what you are trying to accomplish. Next, I would start with the DP User Guide and basic videos, then consult your interface's documentation to see how it all goes together.
