Changing font size of track names
lampfilmusic
Post by lampfilmusic »
I can't find it in the manual or in DP's preferences window.
Please could someone tell me how to change the size of the font of track names in the track window?
Thank you! :P
Re: Changing font size of track names
⌘ ↑ or +
There's also the vertical zoom in the lower right. Note that the font size only bumps up every few zoom level settings, so you might not see a change unless you zoom a few more clicks in.
Or use the scaling feature to make everything bigger. You can then apply the usual controls to reduce the size of graphical images while the text stays at the larger size.
lampfilmusic
Got it. Brilliant. Thank you! :D
