MOTU 8pre USB
ChipBurns
MOTU 8pre USB
Post by ChipBurns »
I want to expand my 828es to 16 inputs. I'm considering the 8pre USB as an A/D converter, using the 8pre optical out to my host 828es.
I'm not sure how the 8pre receives clock/sync. Is it through the optical? As I understand it the 8pre defaults to converter mode if there is no USB control present, but I don't see how the 8pre is slaved to the 828es.
By the way my long term goal is to build an AVB-based system with 32 inputs. I have found used 8pre USBs on e-bay for about $200, this is a short term quick/dirty/cheap path to 16 channels for now.
Thanks for any input/suggestions
rwandering
Re: MOTU 8pre USB
Post by rwandering »
I do not have one of these, but do something similar with a Clarett OctoPre.
Looking at the 8pre USB manual, you can adjust the clock source from the front-panel (i.e., the volume dial).
Robert W. Anderson
MOTU 828es (had an Ultralite original, mk3, and AVB)
Helix & Clarett+Octopre
Presonus S1 (formerly Sonar)
PreSonus MonitorStation
Event Biamplified 20/20
Primarily play PRS, Gibson Les Paul & EC-30.
