Random note lengths in MIDI
- midilance
I have a bass track. It has a note 3 beats in length but plays for only 1 beat in length. This happens randomly. I can go back and play it again and it might play correctly. Is this happening to anyone else?
Mac Studio m2 Max // OS 14.7// DP 11.34 // MotU Ultralite mk4 // Komplete Ultimate 15 // Arturia V Collection 9 // Korg Collection // Stylus RMX 1.8 // Omnisphere 2.6.2c // Scarbee Keys and Basses // T-Racks 5 Max // Amplitube 5 Max // BFD3 // Blue3 // PolyM //
Re: Random note lengths in MIDI
Double-check to see if there's a duplicate note "underneath" it. Even in that case, you wouldn't expect the note to cut off, but there is that "glitch" that was "fixed".
Stubbs' answer likely the correct one, but could also be a stuck note (round robin) that can be reset by All Notes Off command or Disabling/Re-enabling the VI.
Overlapping notes will cause this but I experience it only on imported tracks. When that happens, I highlight all, hold down the Command key and drag the end of one note to the left a little. This shortens all of the selected notes.
I had a similar problem once except the bass notes kept playing way past their duration. After being baffled for a few days, it turned out that the template was corrupted.
iMac 27" 3.6 i9 2019 OS 10.14.4 40Gb RAM, DP 10.13 & 11.11
Mac Mini M1 2020, OS 12.4, 8GB RAM - DP 11.11 - Komplete Kontrol A49
Moved to the Troubleshooting/Criticism forum
