The plugin window gets stuck on top of the DP 11 and I can't move it
I use DP 11.31 and OS Monterey. I have a random problem with various instruments. When I open a plugin (like Superior Drummer 3) the plugin window gets stuck on top of the DP 11 and I can't move it. I've never had anything like this before!! Has anyone had this problem? I have two monitors, could it be due to the resolution of the monitors? I repeat, it's a problem that happens to me often but not always. Thanks for the help
Re: The plugin window gets stuck on top of the DP 11 and I can't move it
Do you mean the head of the plugin gets stuck towards the top of the screen? I have two monitors and have this happen from time to time.
In any case, selecting the plugin you can use the shortcut "command w" to close the plugin window, and in the above case that occasionally happens to me it solves it and the plugin is no longer stuck.
