Long processing times after recording
Irimi Nage
Post by Irimi Nage »
This started maybe a year ago? I'll record something, let's say a guitar take or whatever. Nothing too intensive - a 10 second, mono recording at 24/48k.
On hitting stop the audio will play back fine right away, and edge editing the newly recorded soundbite will work.
Its waveform draw, however, will not appear on screen for 10-60 seconds. Sometimes the waveform displays during recording, or right after, as would normally be expected. Either way, the following still happens-
Changes to the soundbite's gain won't stick for maybe 30 seconds. I can open the "Set Bite Gain" dialog and hit enter but no changes happen and the action is not entered into undo history. Same with fades.
If the recording is a short snippet, like just a few fill in notes, I'll often have to wait LONGER than the length of the recording before I can do a quick adjustment and move on. So I'll wait 30 seconds for a 5 second snippet to finish whatever mystery processing is happening behind the scenes.
During this wait there is no activity in the Background Processing window.
"Wait until DSP Analysis is needed" is on, as is "Play the old, unprocessed soundbites".
"Automatically analyze beats and tempo" is off.
"Always record pre-roll" and "Enable Retrospective Audio Record" are on, but it almost never works 100% anymore. I have a thread or two about that here :deadhorse: Theyre set to 30 sec pre and post, and 1 minute/1 GB, respectively. I need these enabled for my workflow, even in their not-fully-functioning state.
At some point the soundbite kind of flashes as if its processing has been completed. The waveform comes into view if it hasn't, and from this point gain changes are allowed as normal. Occasionally it never comes around and I lose the take.
It doesn't seem to be correlated to the length of the recording.
DP 11.31
macOS 12.7.6
Mac Studio M1 Max
24GB RAM
Anyone know why this may be happening?
Re: Long processing times after recording
I've reported one to MOTU that might be related: If I am zoomed in on a track in either Tracks Overview or Sequence Editor windows, while recording, the display of the recorded waveform lags or, if zoomed in far enough, doesn't show until recording is stopped. Freaked me out first time I observed it (while recording a client's vocal - yikes!)
This has only occurred for me on one or two projects; MOTU could not reproduce. Starting fresh with my template, I don't see the issue. Guessing it may be a plugin... maybe because I had some mastering enabled.
This leads me to ask: Is your issue specific to a project, or reproducible in a new, blank project?
HC Markus
https://rbohemia.com
Irimi Nage
Hi thank you, all projects yeah. I've experienced that one too but it's way less common in my case.
