DP11.32 Automation Data won't show in lanes but records and plays back - RESOLVED
jazzlob
Post by jazzlob »
Just went to edit my automation data in a project in latest DP11.32 . In projects spanning a couple years but have been edited in DP11 -Volume automation plays back, as well as pan, but won't show in sequence editor or MIDI editor as data, lines/bars/ points. Nada. Anyone else have this problem? Automation is enabled globally. Modulation does show when recorded and drawn , volume automation shows in audio tracks. Tried in a new project with only 1 MIDI track, no plugins or instruments- same. Records and plays back automation , vol and pan but won't show when selected or w/ show lanes , if insert selected- only mod is an option, others are greyed out . Any ideas? Is this a bug? I reloaded DP. Otherwise everything else running amazingly well with a lot of libraries, loads of pluins.
Mojove, 10.14.6 96 gigs, macpro 2 x 3.33 ghz 6 core Intel Xeon
Re: DP11.32 Automation Data won't show in lanes but records and plays back
View Filter?
jazzlob
Post by jazzlob »
Yes, after mulling over trying to get to sleep, it occured to me. Turned off in an update, I don't know. Thanks for response. JL
rdtguitar
Re: DP11.32 Automation Data won't show in lanes but records and plays back - RESOLVED
Post by rdtguitar »
I'm having a similar issue. I wrote CC19 automation to the DS Thorn VI and it is working. But in the MIDI Window I can't find a way to view the CC19 data. I read this and checked my View Filter and every box is checked in GLOBAL . If i go to Event List I can add CC19 or click ALL and it does show up in the Event List but I certainly don't want to edit it there? What am I missing?
