When I have the outputs of two audio tracks bussed to an Aux track why do I still hear the direct outputs of the two tracks through the main output? The Aux track seems to be a doubled output of those audio tracks instead of being a controller (or funnel) for their output. It's acting like a send instead of an aux, in a way.
Unwanted output from bussed tracks AND aux
- primeevolutionary
Re: Unwanted output from bussed tracks AND aux
My guess: If you are using a buss, you would want to mute the track channel to only hear from the Aux. If you only ever want to hear through the Aux, instead of bussing, set the outputs to that Aux.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
