Vocalign Project 5 udate 5.1.9.1
apanacci
Post by apanacci »
Hey guys for whatever its worth I downloaded the latest update and it works as ARA in DP. Came out a few days ago. Check it out.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Vocalign Project 5 udate 5.1.9.1
apanacci wrote: Wed Dec 27, 2023 4:42 pm Hey guys for whatever its worth I downloaded the latest update and it works as ARA in DP. Came out a few days ago. Check it out.
Super! Thanks!
I assume you are running it VST3...
apanacci
Post by apanacci »
Yes sir !
sethares
Post by sethares »
There is now an update to version 5.1.10.1. But I'm having two issues with Vocalign 5 project (VST 3).
First, very often. when I instantiate the ARA from the sequencer window, DP crashes. But sometimes, it works fine. I have tried a bunch of things, and can't seem to figure out the "magic" order of commands that keep it from crashing. Do you have a workflow in which it operates reliably? Or do I have something weird in my system?
Second, once I have the guide & dub tracks selected and the output track has everything nicely lined up, what is the best way to send that back to a DP track. I have been using "Bounce to Disk" which works OK, but seems like a workaround. Is there a better way?
Mac OS (Sonoma), DP-11.33, Mac mini + Macbook, Focusrite, Kontakt, Melodyne, Synthmaster, Respiro, WX-7, Starr Controller, Lumatone, Max/MSP, Ozone, assorted plug-ins, many guitars.
sethares wrote: Thu Jan 18, 2024 9:12 am what is the best way to send that back to a DP track.
Can you just select and Merge the subject track? I think. that will do it.
Arceo
Post by Arceo »
Well indeed it does!
Thanks for the tip
TnMike
Post by TnMike »
Can’t seem to get Vocalign 5 to work as ARA in DP. I’m even having trouble with Melodyne keeping in sync. I have to restart DP when Melodyne gets out of sync with song. It just started doing that a couple months ago. Any suggestions?
Thanks, TnMike
Mac Studio 2, 32 gigs ram, DP 11.32
Melodyne studio plugin 5.3.1.018
