Importing BWF Markers
leigh
Post by leigh »
I have a BWF containing markers that was created in RX 6. Is there a way to import that into DP and have DP also import the markers?
**Leigh
Hope is not the conviction that something will turn out well but the certainty that something is worth doing no matter how it turns out.— Vaclav Havel
Mac Studio M2 Ultra, 128GB RAM, Mac OS X 14.5, DP 11.32
Re: Importing BWF Markers
leigh wrote: Tue Dec 12, 2023 5:00 pm I have a BWF containing markers that was created in RX 6. Is there a way to import that into DP and have DP also import the markers?
**Leigh
I don't know of a way to read or embed metadata of any kind in DP. This would include BWF markers.
leigh
Post by leigh »
Thank you, Mike.
**Leigh
Klaus
Post by Klaus »
leigh wrote: Wed Dec 13, 2023 5:55 am Thank you, Mike.
**Leigh
High Leigh
I was searching re: cd burning etc here on Motunation...
I also use DP ( v9.52 )
Some projects I started in Harrison's Mixbus32C,
and now I tried to use DP to import the exported wav incl. markers that I have from Mixbus...
DP can create / burn an audio cd, I know ( with the help of Macos / Coreaudio )
I did that, when the project was done with DP 4 -7
when markers are created in DP, but no markers import ?
Now I found
https://hofa-plugins.de/en/plugins/cd-burn-ddp-master/
and that seems to be the solution to burn from any DAW...
Have you ( or someone else ) used this ?
TIA
and best regards from Switzerland
Klaus
