I have a motu 828 mk3 connected to Apogee Rosetta 800 converter via adat with WC clock (Rosetta master). I connected an eq and an external compressor all wired to pachbay.
In protools 12 the hardware I/O inserts are set to adat corresponding to the physical inputs and outputs.
The analog machines get the signal but in protools nothing, no signal comes, nor do I get any sound. When I disable the hardware inserts, the signal and sound return.
Will I get the routing wrong in protools or in CueMix motu?
Thank you all.
![Frustrated :banghead:](./images/smilies/banghead.gif)
