Blank spots in recorded soundbites...
I first had this happen on Sunday. I recorded the band's take (18 tracks) and we were listening back, and we found a spot, a second or two long, on all of the tracks but two where the audio just suddenly disappeared. I couldn't figure out what was going on as I could see the waveform, but when I selected it to audition, there was nothing played back. When I zoomed in past a certain point, the waveform suddenly dissappeared and showed silence.
This happened to me again today when I was recording a triggered kick track. The track I recorded kept getting 2-3 second sections where there would be a waveform shown, but no sound, and the waveform disappears when you zoom in on it.
I'm running DP 4.52 on a dual 1GHz G4, OSX 10.3.8. Both DP and the OS are newly installed as of a few days ago.
Re: Blank spots in recorded soundbites...
Has anyone else run into this? I'm in the middle of a session and it's got me somewhat freaked.
I had that issue once when I was running DP 4.12 At the time I had stock RAM and was spiking the performance meters. My solution was to increase RAM to 2.5gigs and fiddle with the buffers (depending on the track count). i havent had the issue since. Your recording 18 channels ? Hows the performance meters looking ? Any spikes ?
G5 1.8/2.5g Ram/DP 4.52/OSX x.2.8/Tascam FW-1884/Tascam FE-8/Mach5/Spectasonics/Waves/TC Electronics/T-Racks/Boatload of vintage gear
I'll keep an eye out to see today. As I mentioned, it also did it while recording a single track, though it was triggering a kick sample out of Reason, which may have been a strain on the resources, but we've got 1GB of RAM and dual 1 GHz processors, so I don't see why that should be...Originally posted by Juicy Peach:
What adjustments did you make to the buffers? Increasing the size?
Yes. I increased the buffer size upwards to 1024 and kept the tracking plugins to a minimum. Of course this adds latency for the band. Not only disabling the plugs but removing them during tracking. Ive noticed the problem only in 96k... what are you recording in ? 44.1 ? 96k ?
Had a similar problem in the past. Once opened a project and the last minute of five of my track were blank. Could never really find a answer to the problem. Good luck to you.
You are not alone!
D
You are not alone!
D
Dual PowerMac 1.42 G4
2 G's of Ram, OS 10.3.5
Motu 828
Dp 4.5, BFD, Halion 2, Guitar Rig
Motu 828
44.1. It's behaving itself today. I'm running 14 tracks instead of 18, so that might be a factor. I have just some minimal EQ on a couple of the tracks, so I don't think it's effects.Originally posted by Juicy Peach:
I've been noticing that 4.5 acts at times like 3.1 did in OS9, occassionally freezing, and once or twice actually taking down the whole system and forcing me to reboot. I never had that happen with 4.1
- pencilina
This happens to me all the time. Since v3. Now I'm on 4.52 with a kickin dual g5 and STILL this stupid bullsh•• happens!! _Usually_ it happens the first time I record many tracks after starting the system. After that first glitch things are usually ok. My voodoo cure is to let things roll in record a minute or two and then undo it. This actually works. BTW, I use 2 adats and a 2408 for multitracking (no adat comments please- anybody who would like to send me a 1296 is welcome to). Good luck.
<small>[ April 06, 2005, 02:59 PM: Message edited by: pencilina ]</small>
