Ok so basically, I'm trying to install the latest version on a high end Windows 10 everyday usage / gaming setup but the installer is telling me that the certificate has expired. I dialed the time back to 2019 and 2017 and was mentioned down this thread with the same issue:
viewtopic.php?t=66830
but no avail. What gives?
Performer Lite isn't installing on M2
Re: Performer Lite isn't installing on M2
That shouldn’t be an issue. Make sure you’re trying to install this version:
Performer Lite 11
PC v11.04+90329 | Jan. 25, 2022
Windows 11, Windows 10 64-bit
https://motu.com/en-us/download/
You need to be logged into your user account at MOTU.com to download your license and the UVI soundbanks.
Otherwise, you should call MOTU Support.
Performer Lite 11
I sent Motu a support ticket and they told me that the most recent Win 10 update broke their certificate again, and that I had to set time to first month of past year, which fixed the issue.
Is this suite the correct one for me to put layers on my mic stuff though? Like with my old Presonus Studio 192, I could put compression, reverb w/e from their command center.
Thanks for reporting back.johnnydoe wrote: ↑Fri May 20, 2022 12:10 pm I sent Motu a support ticket and they told me that the most recent Win 10 update broke their certificate again, and that I had to set time to first month of past year, which fixed the issue.
If by ‘layers’, you mean plug-ins, then yes.
