Hello,
Please HELP!!!
When I am switching to headphones, my monitors still working and there is no sound from the headphones.
What could be a problem?
No signal from headphones - Microbook IIc
- Primary DAW OS: Windows
- Kurt Cowling
Re: No signal from headphones - Microbook IIc
Audio interfaces work differently than the built-in audio of your computer, phone or tablet. Plugging in headphones doesn’t automatically shut off the speakers. They allow much more flexibility than that. That flexibility requires you to take control. If the MicroBook is connected to a Mac then install and use the CueMix FX application to control all four output mixes (mix 1 - main, mix 2 - line out, mix 3 - headphones, mix 4 - digital I think). Each of the four mixes can be turned up or down and have a different mix of the available inputs.
I hope this helps.
I hope this helps.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
- Kurt Cowling
I see now that you are on Windows. I believe CueMix FX is part of the Windows software installation as well.
- Kurt Cowling
Don’t you love it when someone joins up to plead for help and then disappears...
Check your audio channel settings ....
