Sequence View / Clip View treats Audio File Differently??
rp88.2
Post by rp88.2 »
Project tempo is 102BPM.
I have a single wave file, I drop it in to Sequence view and it show up as exactly two bars (in 4/4) or 8 beats - which is what I expected.
I look at the Soundfile information and it sees the tempo information as 102 BPM. The length is 4.70 seconds which is 8 beats at 102BPM.
I then drop the same file in to Clip view. I go to play the clip and it says it is 12 beats long. It plays the 8 beats and then 4 beats of silence. :banghead:
What is going on?
rp88.2
Re: Sequence / Clips View treats Audio File Differently SOLV
Post by rp88.2 »
Ok... figured it out...
The data for clip - only visible in 'Clip Editor' says the clip is 12 beats.
This must have been inserted in the ACID file by the producer. So, in Clip view, it looks at the Clip data as opposed to the Audio file data.
Note to Self -- when using clips in Clip view - ALWAYS have the Clip Editor open to verify that the Clip data matches the audio file data.
Michael Canavan
Post by Michael Canavan »
rp88.2 wrote:Ok... figured it out...
Yep, depending on the loop, it can be all over the place length wise. Old Apple Loops as expected work just fine.
