Hi everyone,
it's a long shot, but let's give it a try:
has anyone setup the combination from the title to work?
I wanted to use Transmidifier (TM from now on please) for keyswitching, layering and divisi.
So far I've installed LoopMidi which creates a virtual MIDI cable, and routed a MIDI track from DP through it to TM.
The problem now is getting it FROM TM to VEP. I don't see VEP offered in TM outputs.
In the VEP server there's the option to enable TM as external MIDI, but it doesn't create the output I'm looking for in TM.
What am I missing? Having this working would be a major boost in my workflow...I haven't solved the issue of keyswitching between Kontakt instruments successfully, and I may need it a lot soon.
Alternatively, any other recommendations for solving my problem?
Thank you
Transmidifier+VEP and Kontakt in DP on WIN 10, help
