Hardly any samples, yet snap crackle and pop?
I don't know if this is the proper area for this question, but: Mac trashcan, 16GB memory, terabyte internal drive, samples and sessions on individual terabyte SSD drives in a Blackmagic enclosure, OS 10.9.5, DP 8.07, Kontakt 5.5.2.880. I have four instances of Spitfire Chamber Strings loaded into one instance of Kontakt, with just one microphone setting selected and "purge unused" selected (I know this is very sample-specific, but just in case) - point is, just four VI's loaded) and I'm getting a lot of gnarly digital interruption on playback. Yes, the buffer's set at 64 for doing input and it would sound ok if I went to 1024 for playback, but that's not practical for writing. It seems this shouldn't be such a problem...I have the host buffer multiplier at 1 and work priority at "high." I'll freely admit I've never really understood how those two setting work so before I start messing around with them, too, I thought I'd inquire here: is there something obvious I should be doing to make things smoother? Or, even with this system, do I have to suck this up if I want to use really detailed libraries at such a low buffer setting?
- Kurt Cowling
Re: Hardly any samples, yet snap crackle and pop?
Use four instances of Kontakt instead of one, each with just one spitfire strings. Spreads the load across the multiple cores.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
I see - well, I've heard of this before, but it seems I'd just end up with dozens of instances of Kontakt before was through with a typical project. Is this how you do it even when you've got a lot of instruments to handle?
- FMiguelez
I think you need to do something to Kontakt´s memory management. Something needs to be tweaked so it doesn´t interfere with DP. There´s a recent thread about it.
I can load lots of instruments in Kontakt, spread into one or many instances, and everything is smooth as silk. I do host Kontakt in VE Pro, though.
- Kurt Cowling
I think they heavily scripted instruments need to be in their own instance of Kontakt.
