Stop adding -mg to merged audio name
I do not like having the -mg added to my merged audio file's name ... is there any way to turn that off and just have it take the exact name I give it in the track? When I merge a track that I've edited, with all the little cuts and fades - I name it with a new name and I do not want DP sticking that -mg there. Thanks.
DP 11.22, Mac Pro 14,8 macOS X 14.5, 128 GB RAM, Apogee Symphony MK II I/O, Apollo x8p, UAD plug-ins, PSP, Waves Mercury, NI Komplete Ultimate 14, Spectrasonics, Hollywood Orchestra, Spitfire; Symphobia, Los Angeles Scoring Strings, True Strike, VSL, real violins, guitars, mandolins, pianos, drums, percussion & lots of other stuff...
Re: Stop adding -mg to merged audio name
It's probably there so the SB window can sort the list by type of creation. Just a guess. I don't know if or how to change that.
I just hate it ... I have to transfer to Pro Tools for some projects and when I have 80 or 90 tracks, I have to start each one from measure 1 beat 1, and I merge the tracks individually. I have to make sure that I'm not missing any mutes or odd cuts or fades. Then I save it as an AAF Interchange and certain things transfer without a hitch and others do not. Bottom line, Pro Tools does not like or need the -mg and I just wish there was a way to turn it off.MIDI Life Crisis wrote:It's probably there so the SB window can sort the list by type of creation. Just a guess. I don't know if or how to change that.
And by the way, when i remove each -mg form the name, DP functions just fine. It does not hiccup or seem to need the extension in any way shape or form. I just have to remember to change it both in the track name as well as on the Disk name. The problem is ... 84 tracks ... one by one ...
- danworks
It's not the perfect solution but with "A Better Finder Rename" app, I think you should be able to get rid of the -mg to all the merged audio files with a single click.rosindabow wrote:And by the way, when i remove each -mg form the name, DP functions just fine. It does not hiccup or seem to need the extension in any way shape or form. I just have to remember to change it both in the track name as well as on the Disk name. The problem is ... 84 tracks ... one by one ...
You can do bulk file renaming right in the Mac OS now. Google it.
... and if you don't have Yosemite, there are free bulk rename utilities.
- doodles
don't know about the -mg naming, but this is what I use all the time when I've mis-spelled stems.
http://namechanger.en.softonic.com/mac
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
- danworks
With stereo interleaved files should be easier cos the only suffix is ".wav" or ".aif". With de-interleaved files is more tricky cos there's also the ".L" and ".R" suffix you don't want to change nor erase.
I've found a way to batch renaming audio files using "A better finder rename". As you can see fm the picture, using the option displayed removed the "-mg" leaving intact the suffix ".L.wav" ".R.wav".
Good luck …
Good luck …
- Tritonemusic
I suppose an option would be best, but I actually like seeing which files have been Merged when viewing the Soundbites window.
DP 10.13, OS 13.7.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
I agree - an option to turn this on and off would be best. This was something that MOTU added later - it was not always like this.Tritonemusic wrote:I suppose an option would be best, but I actually like seeing which files have been Merged when viewing the Soundbites window.
I don't know what the big deal is. If you freeze a track, a new wav file is created with a name based on the original (i.e. Guitar.wav -> Guitar freeze.wav). If you punch in or otherwise over dub a track, a new wav file(s) is created with a name based on the original (i.e. Guitar.wav -> Guitar-02.wav -> Guitar-03.wav). If you apply a plugin like reverse, a new wav file is created with a name based on the original (i.e. Guitar.wav->Guitar-reverse.wav). AND SO ON.rosindabow wrote:I do not like having the -mg added to my merged audio file's name ... is there any way to turn that off and just have it take the exact name I give it in the track? When I merge a track that I've edited, with all the little cuts and fades - I name it with a new name and I do not want DP sticking that -mg there. Thanks.
I don't see why it should be any different for merge. IF there was an option to NOT append the -mg, what would it do? Overwrite the original? Kind flies in the face of the non-destructive nature of the program.
Personally, I don't know why they decided to abbreviate merged to mg. They don't abbreviate freeze or reverse, etc.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
It has to do with work flow. If it was only one track, that wouldn't matter. It has to do with transferring large files with 80 or more tracks to Pro Tools and uniformly merging them all so that they start at measure 1 beat 1. Then I have to save the session as an .aaf file to be opened inside Pro Tools. When I do this I am renaming all the files so I can consolidate the session and only transfer whole, complete audio tracks and they have a consistent name so I know all of the tracks that I wanted to transfer made it. I've found that extraneous letters like the -mg causes issues in this process.cleamon wrote:I don't know what the big deal is. If you freeze a track, a new wav file is created with a name based on the original (i.e. Guitar.wav -> Guitar freeze.wav). If you punch in or otherwise over dub a track, a new wav file(s) is created with a name based on the original (i.e. Guitar.wav -> Guitar-02.wav -> Guitar-03.wav). If you apply a plugin like reverse, a new wav file is created with a name based on the original (i.e. Guitar.wav->Guitar-reverse.wav). AND SO ON.rosindabow wrote:I do not like having the -mg added to my merged audio file's name ... is there any way to turn that off and just have it take the exact name I give it in the track? When I merge a track that I've edited, with all the little cuts and fades - I name it with a new name and I do not want DP sticking that -mg there. Thanks.
Bottom line is this: To me it is a big deal - that's why I posted it. To you, obviously not. That's what this forum is about. I'm looking for suggestions and help.
Sometimes you also get discussions. That, too, is what this forum is about. (If I may speak as the person who runs/owns it.)rosindabow wrote:Bottom line is this: To me it is a big deal - that's why I posted it. To you, obviously not. That's what this forum is about. I'm looking for suggestions and help.
I completely agree. Discussions are always welcome - it's a matter of feeling like my issue is real for me and we can discuss it from that point of view - that the starting point is a valid concern for the person posting. Always up for a lively debate.James Steele wrote:Sometimes you also get discussions. That, too, is what this forum is about. (If I may speak as the person who runs/owns it.)rosindabow wrote:Bottom line is this: To me it is a big deal - that's why I posted it. To you, obviously not. That's what this forum is about. I'm looking for suggestions and help.
I lie the various batch revision approaches offered in this thread.
