This is unusual, because I rarely use templates. Ordinarily, I pick out a project that most resembles the one I'm about to work on, duplicate it, rename it, and customize it. I duplicate the track layouts, then delete the old chunks with data. This method just saves me a lot of time when there are a lot of tracks. The fact is, in 25+ years of DP, I have rarely started a file from scratch. Some of my files originated 25 years ago and have been copied, modified and saved so many times that I can't even tell you where they came from. So, one of my weakest areas in DP is actually the one that every beginner faces: set-up. Ok, I'm no beginner, and I'm perfectly capable of setting things up, but by "weakness," I mean that I'm just insecure in the sense of wondering if there is something I missed, especially if something goes wrong.
Immediately I started having problems. Two problems to be specific. I could not get any output from my MOTU 896mk3 hybrid. I'm recording MIDI with a Yamaha WX5, driving a VSL dimension cello, so there are plenty of places that something could be going wrong. So, I recorded a little bit, silently, and found that indeed it was receiving the WX5; my MIDI track appeared filled with notes and controllers, so I knew that was working properly. But why did I not hear it? It was record enabled. It was in audible mode. I should have heard something.
So, I played it back. Still no sound. I put it on a loop and began working in CueMix, because there was clearly output happening on the 896's meters. It wasn't going through the speakers, though. After some experimentation, I found that if I engaged an effect in CueMix, such as reverb (in CueMix FX), and adjusted the send and return, and other controls, I could hear the audio going through the effect.
Ok, so here is how it stands: 1) new file made from old template. 2) 896mk3 hearing it but not passing the audio to a track. 3) FX (Reverb in CueMix) passed the audio to the speakers.
But now there is another problem. When I play, there is no MIDI instrument. It's as if I don't have the MIDI track record-enabled, or else Audible Mode is off. But both are on. Why would it not monitor my playing? It records MIDI if I start recording. It plays on playback. But it won't listen to me when I'm playing between takes, and there is NO SOUND when I'm recording. I rebuilt my bundles and looked everywhere for what I was missing.
Don't stress over this. I solved the problem, but not in the way you probably are expecting. I fiddled with this for about 2 hours. Finally I realized that precious work time was slipping away. I closed the file, threw it out, and I opened a new EMPTY file. NOTHING in it. No templates, no chunks, no instruments; nada. In 5 minutes I had all the tracks I needed, all the routing completed, and it monitored my playing between takes and while recording. Audio passed through the 896mk3 correctly. Everything worked.
Moral of story: know when to hold, and know when to fold. I should have folded up that file after about 10 minutes when I could see that things were not working right. But my insecurity that "maybe I missed something... maybe there are new controls... maybe I've completely forgotten all that I know..." is what got me. I was determined to force that file to work. I was going to go over every possible setting, bundles, routing, all of CueMix FX, and everything until I figured out what was wrong. I finally realized I was licked, kicked out that file, deleted it in the Finder, emptied the Trash, and I started over.
If I had done that in the first place, I would have gotten an hour and 55 minutes of extra work time. But I sat there and fiddled and fiddled and fiddled until I was about to pull out my hair. Folks, don't be insecure. When it's not working, toss it and start over. It'll be faster than trying to figure out what's wrong with your template.
I now think I understand the problem. Those templates were made probably 10 to 15 years ago. I've since replaced my 896 with the 896mk3, not to mention a new Mac Pro (15 years ago I was probably using a Mirror Door G4 PowerMac tower, and I've been through at least two towers since then), and then there's the 32 bit to 64 bit thing, and OSX 10.9.4 beta, DP 8.06, and who knows what all? The template just didn't know what to do! It's remarkable that I can open ancient files and they'll work, but I think DP runs a conversion utility on them when opening them. Apparently it doesn't do that with templates.
So that's my tale. Don't waste your time busting your head against the wall.
