about 1.5
Moderators: James Steele, ssp
about 1.5
Hello all - I just want to be clear about something. The only actual new content as far as sounds go is the beat box anthology...is this correct.? All other new genres are based on patterns of the sounds that we already had in v.1 ? Thanks.
Re: about 1.5
The new Uvi Soundbank uses new presets + sounds from Anthology along with. I uninstalled the previous Bpm + soundbanks, and reinstalled using the new ones..Mine works perfectly.There are new sections NOW- kits+patterns that we're present in 1.0,are in a folder called - HipHop-RnB,plus theres a bunch of new folders,and presets.If your a windows user, wanna be safe,uninstall and reinstall as mentioned in the manual.ENJOY!
Re: about 1.5
Also for what it's worth the Anthology bank is better then the one I bought,the kits are all filled up
Re: about 1.5
Anthology is definitely great!!! I am on a mac, I did not uninstall the old version. I just intalled 1.5 then replaced the ufs soundbanks with the new ones. I hope i didnt have to uninstall first. oh well but it seems everything is woking fine so far so i guess on a mac there might not be a need to unistall the old version??
Re: about 1.5
see below
Re: about 1.5
on the mac uninstall first then install the new update, this is in the pdf manual also.
Too many synths to mention!
Re: about 1.5
I am on the mac - i did not uninstall. Do you think I should redo everything? I dont think i had a problem. Also SSP can you confirm the sampling bug? thanks
Re: about 1.5
If I get a chance to at some point tomorrow I will check it out for you, I am upto my eyeballs in electronics at the moment testing this new hardware I am making. As soon as I can I will see what happens for me.
Re: about 1.5
I believe the uninstall was/is more PC specific. I did not uninstall. I'm on a Mac...
Re: about 1.5
Frank, every revision on the mac while testing was uninstalled prior to installing the next update. on the pc it just over-wrote.
