Basic Stereo Pan Question
lamboguy
Post by lamboguy »
How do you do it?
:lol:
All this time I've used a "real" external mixing board (Fostex) and now I'm doing everything in the computer. I just installed Ivory and I go to pan it to the right and...nothing.
I checked the manual and don't see anything particularly earthshaking about this.
What am I doing wrong? I've got my Ivory track in the Mixer and when I pan left or right nothing happens. (I also turned Stereo Width down to zero in Ivory to see if that was it -- no difference)
Thanks,
Fred
Mac Mini 2.26GHz Intel Core 2 Duo / 4Gb 1067 MHz DDR3 | OSX 10.5.6 | Lacie mini ext-HD 160GB 2MB Cache 7200rpm | DP 5.11 | Ivory | TruePiano | MOTU MSI | Kontakt | iMic audio i/o | M-Audio Keystation 88es | Stewart PA-100B PowerAmp | Yamaha NS-10M monitors | http://soundcloud.com/fredparoutaud/" onclick="window.open(this.href);return false;
philbrown
Re: Basic Stereo Pan Question
Post by philbrown »
lamboguy wrote:How do you do it?
:lol:
Thanks,
Fred
Not sure, but have you checked your audio bundles to make sure they're assigned correctly?
Are you panning the VI or the MIDI track? I think you have to pan the VI (audio) track in most VIs. Same for volume automation - at least in the VIs I use.
Mr_Clifford
Post by Mr_Clifford »
MIDI Life Crisis wrote:Are you panning the VI or the MIDI track? I think you have to pan the VI (audio) track in most VIs. Same for volume automation - at least in the VIs I use.
Yeah. Less and less VI manufacturers are programming their VI's to respond to the basic MIDI control messages like pan & volume these days. Not too much of a drama with a mono-timbral VI like Ivory, but a real pain with multi-timbral ones like the Kompact player that comes (came) with a lot of the East West libraries.
However, you'll find the pan knob a little limited with stereo tracks in DP, and you may want to put a 'trim' plug-in on the track to do more specific panning. - The 'trim' plug-in lets you control the volume, panning, and polarity of each of the L & R signals individually.
DP 9.52 Mac Pro 10.14.6 RME fireface800. Sibelius. Dorico 4
lamboguy
Post by lamboguy »
Thanks all -- armed with all this info I will attack the problem later today.
Much appreciated!
Fred
Tim
Post by Tim »
Yeah.
In DP the 'Pan' on a stereo track is really a balance control, not a pan. In other words, with a source like a close miked stereo piano where the high notes are on the right, and the lows on the left, turning the balance pot to the left will just turn down the right hand mic, resulting in mostly/only low notes being heard.
With the two separate pan controls in the Trim plug the L/R placement of the whole instrument can be panned, leaving the balance (relative levels) between the left and right 'mics' the unaltered.
adeptusmajor
Post by adeptusmajor »
Yeah.
wow
that's good info
i don't think i've ever even used the trim plugin
figured it was just a basic gain control, i had no idea that it could do that
i'll check it out now, thanks :D
Tim wrote:In DP the 'Pan' on a stereo track is really a balance control, not a pan. In other words, with a source like a close miked stereo piano where the high notes are on the right, and the lows on the left, turning the balance pot to the left will just turn down the right hand mic, resulting in mostly/only low notes being heard.
Man... this does NOT sound like how it should work does it?
Whew! Good to know!!
stephentayler
Post by stephentayler »
Yes this one of the only niggles I have with DP as opposed to PT, where stereo tracks have 2 tiny panpots for the left and right. Sure, one can get round this with the Trim plug, but when working with stereo tracks in 5.1 there is no way to have complete independent control over the left and right pan. DP's surround panpots give you individual control of left and right, but they both stay linked in the front/rear plane.... another case where PT's dual panpots allow complete control.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mr_Clifford
Well.... stereo channels on mixing desks often have a balance knob instead of a pan knob, but at least it's labelled 'balance'. As stephentayler pointed out, really the only way to get proper panning on a stereo track is to have separate controls for Left & Right.
burp182
Post by burp182 »
Remember, piano does present a little bit of a special situation in that the tonality differs from side to side in a VERY specific way. On most "stereo" sources like a synth, the stereo is often generated from the effects and so decreasing the level on one side or the other won't change the character of the sound.
DP 7.24, Mac 2.8 8 core, 10GB RAM, 2 UAD-2 Quad, a massive pile of plug-ins and 3 slave PCs with VIs. VEP to connect everything.
