DP11.31 CRASHING ISSUES......; help
a.melani
Re: DP11.31 CRASHING ISSUES......; help
Post by a.melani »
the graphic card seems to be supported so..... I switched to mojave and I stayed on DP11.31
I trash preferences, and I restarted.
Result>>> dp CRASH at fist lauch of a mix project :?
SO I switched to another version of the same project with no plugins.
I didn’t have much time to test but it seems to be working without any plugins, (just 10 minutes test).
I will test monday adding plugins and see what happens.
some questions about plugins, I am ashamed to admit that some Plugins are not original.
-Some K plugins could compromise the system EVEN IF they are not loaded in the session?
-I use a plugin wrapper Novation automap and a plugin host to load different plugin on the same insert slot, These tools could be responsible for crashes?
- somehow my keyboard shortcuts that overlap with DP’s main shortcuts might be responsible of crashes
- I MUST POINT out that rarely the system crashes during recordings sessions where I use very few plugins
thanx
HCMarkus wrote: Wed Nov 06, 2024 9:34 am Since 11.33 was announced/installed, I've experienced one hard "poof-DP gone" crash in a lot of hours of work on some pretty big projects including audio and MIDI VIs. No significant time lost thanks to auto save (although I always wonder if auto save is the culprit... )
Hmmm. Now I wonder about this, too.
a.melani wrote: Thu Nov 07, 2024 8:39 am I have a nvida geforce GTX680 2048 mb
i suppose it supports metal
According to Apple, it does.
a.melani wrote: Thu Nov 07, 2024 8:29 am
in the folder you mentioned there was only audio unit info "cache 64-bit"
And you deleted it, right? Good. I’m now doing it once a year.
a.melani
Post by a.melani »
a.melani
Post by a.melani »
if I suspect a particular plugins, you think in enough to move it out of his folder so that no loaded on DP11?
a.melani wrote: Fri Nov 08, 2024 11:17 pm if I suspect a particular plugins, you think in enough to move it out of his folder so that no loaded on DP11?
Moving the plugin out of its proper location (while DP is not running) will work.
Or, you can just disable suspect plugins in DP, which will trigger a restart of the audio system..
a.melani
Post by a.melani »
Freaky stuff on my DP
I moved out some plugins seems to be causing the problems.
in my crash report chat gpt suppose
slate trigger2 demo, blue cat pathwork and MAS dynamic are the guilty....
without them the system seems to be more stable, but I'm pretty sure the graphic card is involved to.
upgrading to mojave some plugins are blanked on my mean monitor display and works fine on the second one, but if I work with two monitors some time I noticed some crash
Moved this to the "troubleshooting" forum.
a.melani
Post by a.melani »
How can I move all post on troubleshot forum?
May be and admin can do that move all the post
a.melani wrote: Tue Nov 12, 2024 1:47 am How can I move all post on troubleshot forum?
You can't move posts. Only I can do that as administrator. They are all part of this topic... and the topic has been moved. Just in the future remember that posts seeking help with problems should be posted in the "Troubleshooting/Criticism" forum.
a.melani
Post by a.melani »
Thanks you James.
a.melani wrote: Tue Nov 12, 2024 9:28 am Thanks you James.
No problem. I do hope this forum has been helpful to you. We can't always figure out every issue. :(
a.melani
Post by a.melani »
I Will update this topic sono ,
Because some of mynissues are not solved anymore.
The gui of some plugins on mojave are not displayed.....
I move back ti 11.22 and It seems more stable exception for some guis
a.melani
Post by a.melani »
all my meldaproduction plugins, the free ones, the orignial ones and the K'ed ones are blanked..... cannot understand
opening those plugins on my main monitor the GUI is blanked, if I open on the second monitor the GUI is correctely displayed, and others windows in plugins are inavailable.
Cannot understand, if I open the same plugin in logic or in izotope ozone, they works fine.....
