It's a fair question-- which begs the question of why we're still dealing with DAE, RTAS, VST, etc. Everyone wanted their own engine format-- as with samplers, companies pushed to have their formats become the next "standard", but it never quite turned out that way. Instead, software is released with 4 or more versions on one disc, letting you choose which would work-- and that includes AU.boonier wrote: Incidently, why does DP use MAS? I never understood the relevance of running an extra layer on top of Core Audio. If core audio is the holy grail of system level audio integration, why did Motu choose not to adopt this when they went to OSX? Au plugins even run in a MAS wrapper.
It seems obvious to me why Logic wins over DP cpu wise - Its using CoreAudio as its audio driver!
Understood-- DP defaults to MAS. It even skips the AU Exam for it's own VI's even when they've been installed. If you want to use the AU version of MachFive, you have to use a different app.
MAS is just part of the longstanding code, for good or ill. It's probably more trouble to remove it than to keep buffing it. But I doubt HDTM, RTAS, VST or other proprietary audio engine formats are going to go anyway too quickly, especially if PC world needs them.
Honestly, AU is only now feeling a lot better, and if DAW makers in general were to ever make AU the universal norm, the unique respective audio format engines they spent so many years developing will not go away quietly if they were ever to go away at all.
The most puzzling thing is that DP is Mac-only. MAS does appear to be the glass wall of sorts between the OS and the app.: transparent but rather peripheral.
-- Are OSX and AU increasingly making a denizen of DP/MAS?
-- Just how much fat will be trimmed with the Intel-native rewrite?
-- Will Miss Pellings keep her baby?
duh-duh-DUUUUUUUH
<dramatic chords>
Catfishmusic and Timeline may be the first ones to tell us these and other developments. I may have to TiVO this thread so not to miss anything.
