corbo-billy
Re: Kontakt 8.4.0 released today
Post by corbo-billy »
James Steele wrote: Tue May 20, 2025 4:06 pm Kontakt 8.4.0 released today
You can launch Native Access and read about what's new. I'm too tired to try to screen capture the list, covert to text, and then post here. Besides... I post 75% of the posts in this topic anyway and I'm gonna scale back how much effort I put into it. Only so many hours in the day, you know? ;)
I did a full Time Machine backup before updating. It'll be a while before I trust Native Instruments 100% again when it comes to Kontakt updates.
Minor update in 8.4.1. version for Kontakt 8 :
_ ADDED Data Tracking about Default vs Classic View settings
_ FIXED File Menu (Load Recent) stays open if cursor is on hover after load
_ FIXED On MacOS some Content Libraries not found from external drives, due to wrong path construction
Steinberg HALion updated to 7.1.40
Not sure what's been updated. Went to Steinberg web download area and update notes did not appear to be... well... udpated.
Audio Hijack updated from to 4.5.1
Updated in Audio Hijack 4.5.1:
New “Spoken Content” Special Source
On MacOS 15 (Sequoia), the new “Spoken Content” special source replaces the previous “Text to Speech” special source. It captures audio from the “Accessibility” settings “Spoken Content” area, as well as from apps which play text-to-speech audio via the system (triggered by the “Start Speaking” command in the “Speech” menu).
Newly created presets once again enter edit mode when created, allowing their title to be edited immediately. This fixes a regression introduced in 4.4.5.
Saved presets in the “10-Band EQ” effect once again correctly show their name, rather than “Manual”, fixing a regression introduced in 4.5.0.
The “Transcribe” block no longer shows an error when the selected destination folder has been deleted. Instead, the folder is automatically re-created at the start of the session, matching the behavior of the “Recorder” block.
If an output device’s preferred stereo channels update while in use, Audio Hijack will now automatically start using the new channels, rather than requiring a session to be stopped and restarted.
Issues where windows moved to secondary displays could have incorrect window widths have been corrected.
A drawing issue which could result in dark text on a dark background in the “Recorder” block has been corrected.
Imaginando's GRFX Audio Unit plugin will no longer cause the RemoteAUHost process to incorrectly appear in the Dock.
Several small improvements have been made to work better with VoiceOver’s “Speak item under the pointer” function.
Information regarding Whisper models is now cached by the “Transcribe” block, to prevent redundant network requests.
Louder Than Liftoff Silver Bullet Mk 2 updated to 1.1.0
Update via the Plugin Alliance Installation Manager app.
Version 1.1.0 (May 23, 2025)
3 new Mojo modes based off of an analog model of the Hitmaker Comp Mojo Module
Analog Noise settings in options menu (off, low, on). On was the original setting
ABCD Comparison UX enhancements such as copy and paste
DC offset bug fixed through additional filter
"Intro Thump" bug fixed by instantly setting parameters/dsp at start of offline rendering
Gain Recall bug fixed
Not sure if this is the right place —…
I have an ad from Soundpaint for a new CS-80 VI. In it, they say:
ULTRA-DEEP SAMPLED WITH 31.2000 SAMPLES
What does the “31.20000” refer to?
Soundpaint CS-80 VI
I'm guessing it's a boast in the blurb as to how many samples were taken. Generally-speaking of course, higher is better.
I'm tippin' it's a typo.
Could be 3000, 30 000, 300 000... who knows? You'd want your promo guy or team to at least get this right.
Re: Soundpaint CS-80 VI
monkey man wrote: Thu May 29, 2025 10:04 pm I'm guessing it's a boast in the blurb as to how many samples were taken. Generally-speaking of course, higher is better.
It appears to be a typo. If you go look at their promo video on YouTube, in the description it says:
We’ve captured every detail of this legendary instrument, deeper than anyone ever has, with over 31,000 Ultra Deep-Samples™. That means you’ll get everything from dreamy synth pads to punchy basslines and soaring leads, all ready to play and explore.
Not quite sure what's so special about "Ultra Deep-Samples" but they've apparently trademarked that little nugget of marketing hype. (They also put the hyphen between the wrong words IMHO. Seems to me it should be "Ultra-Deep Samples," but what do I know?)
RE: Lexicon plugins FINALLY Apple Silicon Native!!!!!!!!!
FYI... for anybody wanting more info on this release and better details on how to upgrade, I just found this thread over at the Harman/Lexicon forum:
https://proforums.harman.com/lexicon/di ... ad-here/p1
James Steele wrote: Fri May 30, 2025 12:03 am
Thanks James. Had a feeling it would've been around 30 000, similar to another analog-synth deep-sample they did a couple o' years ago. They've probably done others too; I've no idea.
Agreed - they placed the hyphen in the wrong place. They should've gone the whole hog and said, "Sample's". :lol:
Right. You have to wonder what else they got wrong if they made such a blatant error.
corbo-billy
Voxengo Drumformer 1.12 update
This update includes the following changes:
* Fixed HiDPI VST3 GUI resizing issue in Cubase, on Windows.
* Made codebase optimizations.
* Reduced GUI refresh jitter.
* Fixed occasional GUI flickering on macOS (due to usage of Device RGB color-space, now it is sRGB).
* Improved audio-UI interoperability, to reduce a chance of audio stutter happening when UI is active.
https://www.voxengo.com/product/drumformer/
Pulsar Audio Updates
Looks like they updated most if not all of their plugs.
https://pulsar.audio/download/
Steinberg Media Bay updated to 1.3.10.42
This seems to just have happened today. Launching Steinberg Download Manager will automatically updated Media Bay.
Softube Updates
Softube Updates
Several Softube plugs updated from 2.6.4 to 2.6.6
The ones I have are:
• Bus Processor
• Clipper
• OPTO Compressor
• Tape
• Weiss Deess
• Weiss MM-1 Mastering Maximizer
• Widener
corbo-billy
Arturia Mini Freak V in version 4
A new verson 4 for the MiniFreak hardware and the soft Minifreak V .
New FX Vocoder Ext IN with 4 Presets : (Clean, Vintage, Narrow, Gated).
New FX Vocoder Self with 4 Presets :(Clean, Vintage, Narrow, Gated).
