real time MIDI recorded early
koheinyc
Post by koheinyc »
after upgrading to DP 11.2 ( I am using DP 11.34 97919 now), the recorded MIDI data is located early.
for exapmle,
At BPM♩=120 with real-time MIDI recording, I played extremely right on the grid time, but the data are recorded about one and half 64th notes ahead(early) of grid. The input quantize if off.
It only happens when recording MIDI data. When I record audio from outboard like synthesizer, guitar, vocal and so on, it is ok.
I hope there is a solition here. And any advice will help.
thank you.
.....Spec.....
DP 11.34 97919
input keyboard : KEYSTATION 61 MK3
Mac M4 pro / OS 15.3.2
buffer is 1024
Phil O
Re: real time MIDI recorded early
Post by Phil O »
Go to Preferences>Play and Record>MIDI Options>MIDI Patch Through Mode
Check your sync option settings there and read about timing in the manual. This might or might not be the problem, but it's a good thing to check first.
There's that check box for Sync Recorded MIDI to patch thru. Not sure if that's a possible culprit. I leave mine unchecked.
Tidwells@aol.com
Post by Tidwells@aol.com »
Yes, counter-intuitively uncheck that box and it should fix your problem.
Doug
koheinyc
Post by koheinyc »
now I check both Patch Thru in background and Sync Recorded MIDI to Patch Thru.
and the problem solved !
thank you guys. I really appreciate it.
Funny how there are one or two of those settings where for one person it breaks it and for another it fixes it.
Can someone explain what the "Sync Recorded MIDI to patch thru" actually does or how it works?
labman
Post by labman »
That is weird.
On our rigs, we keep the Sync Recorded MIDI to Patch Thru checked on the past 18 months.
labman wrote: Fri Apr 25, 2025 5:06 am That is weird.
Wow, that is early.
labman
Post by labman »
stubbsonic wrote: Fri Apr 25, 2025 10:16 am
Wow, that is early.
:rofl:
I meant to say that we moved it from off, to on 18 notes ago, to compensate for the weird timing.
labman wrote: Fri Apr 25, 2025 2:38 pm I meant to say that we moved it from off, to on 18 notes ago, to compensate for the weird timing.
I can't deny I'm not aging so gracefully. It's getting harder for me to remember 18 notes ago.
labman
Post by labman »
stubbsonic wrote: Fri Apr 25, 2025 3:23 pm
:lol:
I'm on fire this week! Remember to tip your wait staff.
