Controller issue
fdcfrank
Controller issue
Post by fdcfrank »
Hi there. I´m having a problem controlling DP via MIDI. I´m trying to control DP via Qlab and when control the ¨Stop¨ and ¨Rewind¨ transport controls the keys kept unpuched. No problem with record, add marker, etc. I changed the velocity from 64 to 127 trying to solve a similar issue saw on youtube but a got the same results. Any clues?.
Thank you very much in advance
Re: Controller issue
fdcfrank wrote: Thu Jan 16, 2025 3:30 am Hi there. I´m having a problem controlling DP via MIDI. I´m trying to control DP via Qlab and when control the ¨Stop¨ and ¨Rewind¨ transport controls the keys kept unpuched. No problem with record, add marker, etc. I changed the velocity from 64 to 127 trying to solve a similar issue saw on youtube but a got the same results. Any clues?.
Could you put that in English, Frank? I'm sure someone can probably help, but that would make it easier to do so.
Yea, I had the same thought. That post is a little difficult to understand.
I think he's saying the stop and rewind buttons don't work. Perhaps try a different Control Surface setup?
