Traveler mkIII no audio out
falcontech
Post by falcontech »
Hello everyone and happy new year
I have a problem with my traveler mk3, from one moment to another it stopped working, the sound card is detected by the system so much so that I also updated the firmware thinking I could solve it, but I have no audio output and the clock LED flashing, sometimes after several shutdowns it freezes but still no audio, I hope someone of you has some help with this problem, I'll try this before sending it in for assistance, I'll start by saying that I disassembled it thinking there was the usual capacitor exhausted but at a glance they all seem good, the drivers have been installed and uninstalled several times without any result, but I exclude a drivers problem because with an audio express (same drivers) they work regularly, same tests done on both windows 10 and macos thanks in advance
Re: Traveler mkIII no audio out
Can it be seen by your computer? Have you tried resetting to factory defaults? What OS are you currently using?
falcontech
mikehalloran wrote: Thu Jan 02, 2025 10:00 am Can it be seen by your computer? Have you tried resetting to factory defaults? What OS are you currently using?
Yes the card is seen by the computer, as I said I was also able to update the firmware, under windows I'm using windows10, with mac I tried it with ventura I also did the reset several times..same problem
