Hello everyone.
I recently purchased two of MOTU MIDI Express 128, which states 8 inputs 9 outputs i.e. a total of 17 I/Os, However when I look at the unit, I see a strange numbering system:
- MIDI Input ports 1 to 7 on rear panel
- MIDI output ports 1 to 8 on rear panel, and
- MIDI input port 8 and output port 8 on front panel.
Why is the Output port no. 8 repeated, instead of calling it no. 9? and what is the purpose of having two output ports with the same number? The digital LEDs anyway show up to no. 8 and there's no number 9 port there.
As a wild guess, I was thinking that perhaps the rear output port no. 8 might be used to connect the MIDI Express 128 to a second MIDI Express 128 - but is that even possible, and is that the reason for the duplication?
Can someone point me to the answer please?
Sorry for sounding childish though.
Confusing Port Numbering on the MOTU MIDI Express 128
- Primary DAW OS: Windows
Re: Confusing Port Numbering on the MOTU MIDI Express 128
Having port 8 I/O on the front and the O on the back is to allow easy access to the ports for the odd device that you don't need a permanent connection. The output should be mirrored.
Exachary mate.
Convenient plug-and-play.
