Import FCPX xml to DP with XtoCC app
buhardilla
Post by buhardilla »
Just to know if anyone has experience with this app from Intelligent Assistance
http://intelligentassistance.com/xtocc.html
This app transcode FCPX xml projects to FCP 7 xml that can be imported in applications as Adobe audition, After effects,... and in theory DP could also import these files
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
Re: Import FCPX xml to DP with XtoCC app
What theory would that be?
A number of DAWs support some form of .xml import but, as far as I know, DP is not one of them. MusicXML import has been on my wishlist since DP 8 shipped without it.
If there's something I'm missing here, please let us know.
buhardilla
Unfortunately does not work out :(
I bought the app and I have tried to import FcPX projects in format XML translated by XtoCC to DP. The results:
Some projects were successfully imported as FcP7 files in DP, but in other projects DP was not able to locate audiofiles. In spite I wrote the correct archive folder location in the warning window DP did not load it. I investigated if this problem was due to permissions issue (relocate the files to other HD etc..) but for some unknown reasons DP didn’t recognize it.
But worse still is the fact that these xml files are flawless imported in After Eff, Davinci R,... :banghead:
buhardilla wrote: But worse still is the fact that these xml files are flawless imported in After Eff, Davinci R,... :banghead:
Apps that support MusicXML import, I’m guessing.
Thanks for reporting back.
I have used Logic Pro X which does support MusicXML import as a bridge between certain notation apps and DP. It works well enough but there are a lot of steps involved — direct import into DP would be easier. The $200 spent on Logic has paid for itself many times over even though I’ve never begun nor completed a project in it. Without knowing the details, why wouldn’t this approach work for you? Logic has a feature where you can export all audio and MIDI to the desktop simultaneously—I use it often and then select what I will open in DP.
Those I’ve talked to at MOTU don’t understand why anyone would be interested in MusicXML import—while touting .xml export as superior to MIDI.
I do have to agree with them on one point: They just don’t get it. :shake:
demonsp
Post by demonsp »
mikehalloran wrote: Thu Oct 24, 2019 12:43 pm
:deadhorse:
Old thread but still relevant.....
'XtoCC" used to be called "Xto7" and worked perfectly to create FCP7 .xml files which DP can handle marvellously.
Unfortunately, it stopped working when it became "XtoCC". (Adobe Creative Cloud/Premiere)
Buying Logic is a solution but DP has the ability to read .xml files which ie. (Blackmagic) DaVinci Resolve can export and other video editors. There's also .aaf files from ie. (Universal Audio) Luna BUT DP needs updating to be compatible.
A massive pain trying to import projects from other programs into DP, without having to buy a utility or another program.
Cheers!
PS. OMF seems to be the best way to import into DP but only Premiere can create them. AFAIK.
Talking video editing programs here.
MBP i5/i7, MacOS 10.13/10.15, MOTU DP 11, Traveller, Track 16.
Dual 867Mhz G4 (MDD), APPLE 17" Display, MacOS 10.4.11, 2Gb. RAM, 4 internal drives (2 x 120 gbs./8mb cache audio drives in ATA66 bus, RAID stripe), MOTU 896HD, 4 x UAD-1, WaveArts Wavesurround Pro, DP 5.13, Reason 3.0.5, Recycle 2.1, Novation Remote 25SL, Mackie HR624, MGE ups.
