5.1 in Stereo Headphones - Best practice
Digital Perfomer in the context of television/film scoring and post-production.
Luichy
Post by Luichy »
Hello.
What would you say it's the best way to listen to 5.1 tracks using stereo headphones in DP?
I don't have a 5.1 setup and I need to preview some mixes that were sent to me. I don't need to hear it at maximum quality, just check the timecode with picture.
dix
Re: 5.1 in Stereo Headphones - Best practice
Post by dix »
The easiest way (not the best necessarily) would be to import the file into a 5.1 track in DP > add a Master Fader, then select Stereo from the Fold-down button on the Master Fader. You'll only hear it in stereo of course. ...I've seen various surround-for-headphones options out there, but have not tried any.
Luichy
Post by Luichy »
dix wrote: Sun Jan 24, 2021 1:22 pm The easiest way (not the best necessarily) would be to import the file into a 5.1 track in DP > add a Master Fader, then select Stereo from the Fold-down button on the Master Fader. You'll only hear it in stereo of course. ...I've seen various surround-for-headphones options out there, but have not tried any.
I'm going to try a plugin called IRCAM Hear but in order for it to work I must make a 5.1 output bundle and DP won't let me add it. It greys it out. I managed to make a 5.1 buss in an aux track. But I actually need a 5.1 output to insert the plugin. When I try to add it it only shows two channels and it's greyed out.
dix
Post by dix »
Do you have a 6 channel+ interface? I believe you'll need one to get DP to create 6 ch Output. If there's a way around this I too'd be interested in how to do it? I need to set up a 13 channel mix with my 8 ch I/O (to eventually be mixed in a 12.1 venue).
Luichy
Post by Luichy »
dix wrote: Sun Jan 24, 2021 2:50 pm Do you have a 6 channel+ interface? I believe you'll need one to get DP to create 6 ch Output. If there's a way around this I too'd be interested in how to do it? I need to set up a 13 channel mix with my 8 ch I/O (to eventually be mixed in a 12.1 venue).
Actually, no, I don't. I'm trying to make it work on my laptop's audio. I'm trying everything. I'll let you know.
dix
Post by dix »
Yeah. I think you'll need to fool DP into thinking there's a 6 ch I/O. ProTools installs an aggregate I/O that I see in the Hardware Setup. I can't get it to work with DP on my cMP, but that might work for you? - it's a long shot. Either way, if what I suspect is true, you'll need to see and select the dummy 6 ch I/O in the Hardware Setup before DP allows a 6ch output.
rp88.2
Post by rp88.2 »
If you need more channels -- try Blackhole - it will create either a 2 or 16 channel virtual interface. It's the modern version of Soundflower.
https://existential.audio/blackhole/
Then Aggregate with your audio interface in DP's audio setup - you will have plenty of channels.
dix
Post by dix »
Perfect! Thanks for this tip. I’m guessing similar routing tools might work too. Loopback etc. I’ll check it out.
demonsp
Post by demonsp »
Greetings!
I've been using "Immerse Virtual Studio Signature Edition" for a while and seems to work well.
It includes a multi channel plugin for piping sound between programs and does surround down to stereo.
Cheers.
MBP i5/i7, MacOS 10.13/10.15, MOTU DP 11, Traveller, Track 16.
Dual 867Mhz G4 (MDD), APPLE 17" Display, MacOS 10.4.11, 2Gb. RAM, 4 internal drives (2 x 120 gbs./8mb cache audio drives in ATA66 bus, RAID stripe), MOTU 896HD, 4 x UAD-1, WaveArts Wavesurround Pro, DP 5.13, Reason 3.0.5, Recycle 2.1, Novation Remote 25SL, Mackie HR624, MGE ups.
labman
Post by labman »
we use dearVR monitor on front of our headphone chain. Or occasionally Waves NX
labman wrote: Sat Oct 05, 2024 5:23 am we use dearVR monitor on front of our headphone chain. Or occasionally Waves NX
In what situations would you use NX rather than dearVR?
labman
Post by labman »
bayswater wrote: Sat Oct 05, 2024 8:59 am
NX is more simplistic so it fits a few of our team who are less tech savvy, where dearVR has a bunch more options and fits a few of our film, peeps better. Sonically they are a bit different too, in how they are handling the actual 'space' type stuff. And they have differing support for the various headphone manufactuers. Most of our guys use SoundID for that kinda flattening for each of the headphone makes and models though, as its far more extensive support in that department. So for our folks, if half dozen of one, half dozen of the other.
labman wrote: Mon Oct 07, 2024 5:15 am
bayswater wrote: Sat Oct 05, 2024 8:59 am In what situations would you use NX rather than dearVR?
Thanks. I used NX until VR showed up. I was wondering if I had missed something with NX. It seemed to give clarity but not so much that was useful in the way of space.
