As of DP 11.3, the Eventide H3000 crashes every time.
Dropping back to 11.22. C'mon MOTU. You can DOTU much better than this.
Re: As of DP 11.3, the Eventide H3000 crashes every time.
I just checked both the H3000 Factory and and H3000 Factory Mk2 plug ins on DP 11.32 running Sonoma 14.5. Loaded instances of both following a Stereo VI and tried different presets and no crashes here. Running the Audio Unit version.MIDI Life Crisis wrote: ↑Fri Jul 12, 2024 2:51 pm Dropping back to 11.22. C'mon MOTU. You can DOTU much better than this.
H3000 Factory is v.3.7.17
H3000 Factory Mk2 is v.1.0.4
Both I think are latest versions.
Thanks, James. Probably A Mojave thing.
???DP 12; Finale 28
IIRC, MLC's sig is a tad out of date.
Preemptive sig so when I do update, it'll be accurate and I don't have to f#$% with it. Can we say "f#$% with it" here?
Sure. We just can’t use the actual F bomb.MIDI Life Crisis wrote:Can we say "f#$% with it" here?
Now who would do something like that???James Steele wrote: ↑Mon Jul 15, 2024 3:56 pmSure. We just can’t use the actual F bomb.MIDI Life Crisis wrote:Can we say "f#$% with it" here?![]()
