Recording with Digital Performer at HALF-SPEED?
primeevolutionary
Re: Recording with Digital Performer at HALF-SPEED?
Post by primeevolutionary »
Hello, Mike,
Page 921 of the most current User Guide is Disabling pre-get operation, FILE-BASED PLUG-IN Processing, Reverse, Previewing a file-based plugin and ARA plug-in processing. Would you please state the chapter and section of the guide? The guide itself changes a little with each revision.
Joe
Macmini9,1 (M1, 2020) 16 GB RAM
MacBookPro15,1 2.6 GHz 6-Core (Intel, 2018) 16 GB RAM
OS X 14.7
DP11.32
2 896 mk3 192 kHz Hybrid FW • USB2
Stage-B16
2 828 mk1s
MTPAV USB
primeevolutionary wrote: Sat May 11, 2024 2:09 pm Hello, Mike,
Joe
Ok... that's weird. It turns out that I am right — and so are you.
Normally, when I look up a manual page, I do it from motu.com—much quicker if I don't want to open DP first—and 921 is the correct page.
Opening it from inside DP, however, pg 943 is correct.
Who knew?? :surrender:
primeevolutionary
Thanks, Mike!
I assumed they’re constantly tweaking it.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
