Apple Thunderbolt 3 to 2 adapter and MOTU audio interface dropouts.
trakzero
Post by trakzero »
I've had sporadic interface dropouts where I've had to reboot all of my hardware before the interface (828es) was recognized again. No trouble with any other hardware. I've narrowed it down to the Apple Thunderbolt adapter. It seems to flake out at times and needs to be unplugged from both ends to get properly reset. That's why it was taking a full studio shutdown at first, that's what it took to get devices at both ends of the adapter powered down.
I've had this issue with other devices using the Apple TB 3 to 2 adapter. Keep this in mind if you get the same dropouts. You may not need to reboot your whole system or anything at all. Just disconnect and reconnect the TB adapter.
Cheers!
Re: Apple Thunderbolt 3 to 2 adapter and MOTU audio interface dropouts.
I had an old TB adapter just up and fail on me, and had to buy a new one, and it worked as it should. Mind you, that was a pretty old adapter.
To compound matters, there were other issues with a newer MBP and FW, unrelated to the adapter. But it was easy to sort because the failed adapter didn't work on an older MBP, and the new one worked on both MBPs
I hope you're not having that kind of issue, because on another thread today I learned that these adapters are getting hard to find. (!)
trakzero
Post by trakzero »
stubbsonic wrote: Sun May 05, 2024 1:35 pm I had an old TB adapter just up and fail on me, and had to buy a new one, and it worked as it should. Mind you, that was a pretty old adapter.
If it happens again and the same fix works, I'll swap adapters. Haven't heard of any issues getting ahold of them, they work bi-directionally and with M series hardware.
Does it work connected over USB 2?
Although that does not support the track count of TB, there is no difference in latency. I the 828es works over USB, this should confirm that the TB adapter or TB2 cable is the problem.
I do not have this issue with my 828ES, Mac Studio, and the Apple TB Adaptor.
HC Markus
https://rbohemia.com
HCMarkus wrote:I do not have this issue with my 828ES, Mac Studio, and the Apple TB Adaptor.
Same here. Maybe it’s just a bum adapter or something?
EMRR
Post by EMRR »
I have connectivity and noise burst problems with 2 different adapters, gave up and moved to USB, solved it. Something's not happy in my system with those adapters. Disappointing.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
EMRR wrote: Mon May 06, 2024 7:32 am I have connectivity and noise burst problems with 2 different adapters, gave up and moved to USB, solved it. Something's not happy in my system with those adapters. Disappointing.
That's a bummer. I know that only the genuine Apple adapters are supposed to work properly. Makes me wonder though, if there are cheap Chinese counterfeits in the market? Although the likelihood you'd get one of those (even if they exist) twice are ridiculously low.
I suspect you could tell by Apple's over-the-top deluxe white packaging-- which I doubt a counterfeiter would bother to replicate (but I may be wrong). OTOH, if they are asking Apple's price, perhaps it would be worth it.
stubbsonic wrote:I suspect you could tell by Apple's over-the-top deluxe white packaging-- which I doubt a counterfeiter would bother to replicate (but I may be wrong). OTOH, if they are asking Apple's price, perhaps it would be worth it.
I would think if it came in the proper packaging it’s legit. It’s a real head scratcher why it some have issues and others don’t. I assume you have latest firmware installed. Just so odd.
I've been hearing for the past several years, that Apple has neglected Firewire, so at some point in OS updates, it'll just poop out.
Oh, and yea, we can't easily roll back an OS when it does.
There is firmware in the Apple TB2–TB3 adapter. A few websites are recommending that the adapter be plugged into a TB3/4 port during a macOS update so that the adapter firmware updates as well.
I have no idea if this is correct since none of those sites are Apple but it’s easy enough to do. One way is to boot into the Recovery Partition and Reinstall your current macOS. You can also download it from the App Store and reinstall that way. Sonoma 14.5 should be dropping any day by my estimate—certainly by the WWDC next month.
mikehalloran wrote: Tue May 07, 2024 9:21 am There is firmware in the Apple TB2–TB3 adapter. A few websites are recommending that the adapter be plugged into a TB3/4 port during a macOS update so that the adapter firmware updates as well.
Interesting.
dgatwood
Post by dgatwood »
I could be wrong here, as the only thing I have to go on is iFixIt's teardown, but assuming they didn't miss anything interesting, if I read the bill of materials correctly, there's basically zero field-upgradable logic in that adapter. It contains:
  • A power IC that, at least when used in Macs, controls the voltage that a USB-C port provides (TI CD3215B03).
  • A power IC and a couple of voltage converters to control the Thunderbolt 2 bus voltage.
  • A bunch of discrete components.
That first chip on the list probably has custom firmware responsible for sending additional messages over the USB-C configuration channel pins (CC1/CC2) that put the USB-C port into Thunderbolt mode. As the only component with any logic at all in it, that's the only part that even could get firmware updates, but it probably isn't connected to the data pins on the bus, so it would be kind of hard to update it, nor is its function interesting enough to warrant firmware updates, realistically.
Apart from the magic hardware that puts the port into Thunderbolt mode and a Thunderbolt-2-compatible DC voltage converter for bus power, as far as I can tell, it is basically a passive adapter, and the Thunderbolt hardware on the motherboard is talking directly to the silicon in the Thunderbolt cable, or, for passive cables, the silicon in the Thunderbolt device.
Chances are, if having it attached while installing a software update made a difference for someone, it is because of what was on the other side of that adapter needing an update, e.g. Apple's Thunderbolt Display, which absolutely *does* have field-upgradable firmware.
That said, take everything I just said with a grain of salt; I'm a software engineer, not a hardware engineer. 😁
Assuming that my analysis is correct, though, then your problem, assuming it isn't just a software bug, seems likely to be elsewhere in the chain. My money would be on the Thunderbolt cable.
Switching to an optical cable might help, particularly if you're getting errors caused by slight timing differences from pin to pin or something, because that would result in only a couple of inches of cable length before converting the balanced signals for each byte lane to optical pulses, and any timing differences in such a short run would theoretically be minimized as a result.
That said, this is mostly theory and speculation on my part. Again, take it with a grain of salt.
Although the 828es supports optical, no TB3 Mac does. Optical was dropped in 2016.
