Tracktion Abyss updated to 1.3.1
Run the Tracktion Download Manager.
Steve Slate VSX System Wide app updated recently
There's been an update recently to Steven Slate VSX System Wide app. You can get it by launching Steven Slate Audio Center app.
UVI updated Xtreme FX 2 again... they mean it this time!
LOL... well they fixed the missing samples.. then they didn't... then they did again. Maybe the got it right this time! LOL
Sononym updated to version 1.5.5
https://www.sononym.net/blog/new-releas ... ersion-155
Version 1.5.5
Added: Remove non-existing folders during refresh of library
Changed: In audio config, audio outputs are enumerated from 1 instead of 0.
Changed: Removed a couple of synchroneous I/O calls.
Fixed: A project folder can appear with the wrong name
Fixed: Drag to create initial project can create invalid link
Fixed: Unable to change/override category of samples using menu
Fixed: Moving content around within library might create ‘ghost folder
Pulsar Audio Primavera updated from 1.0.11 to 1.0.12
https://pulsar.audio/download/
Didn't see a changelog so not sure what's different.
Focusrite FAST Bundle updated (fixes "Failed to access preset directory" bug in Sonoma)
Just got an email today in response to a support ticket I sent about this. Focusrite just updated their FAST series plugs to get rid of a problem in Sonoma.
https://collective.focusrite.com/products/fast-bundle
iZotope Trash update to 1.10
Trash Release Notes
FIXED cross-platform discrepancy in specific waveshapes (Rubber Hammer, Bad Breakup, Faulty Transistor, Uncontrolled Static, Acid, Iron, Citrus Pulp, Cracked Actor, Cracked Actress, Noise Art, and Stomper). NOTE: this fix can affect the sound of sessions and custom presets that use these waveshapes, rendering any critical tracks is recommended before updating
FIXED assorted minor bugs
ADDED support for VST3 resizing on Mac and Windows
Guitar Pro 8 updated
You should be prompted to updated just by launching it or choosing Check for Updates.
Changelog
Release Notes
8.1.2
Playback
Selections of less than a bar are no longer repeated
Selections beginning with a Slide In are now correctly interpreted
Ornaments are now interpreted regardless of their starting fret
The relative tonality is correctly applied to ornaments
Fixes the score cursor behavior when changing tracks
Fixes the score cursor movement with shortcuts during playback
Fixes some random sound automation changes
The count-in is now correctly updated according to the current time signature
Fixes a count-in triggered when activated during the playback
Edition
The Audio Note Settings dialog is no longer modal
Improves the “Select All” performances in Multivoice
Pasting multiple bars to a selection now correctly moves the score cursor to the next beat
The placeholder is no longer taken into account when using the “Bar Arranger” tool
The auto scroll triggered by a click no longer creates an unwanted selection
Texts and Chronos are applied only if selected in the “Special Paste”
Moving strings maintains the previous accidentals (if any)
Notes created when tying to the previous bar are now correctly undoed
Undoing “Repeat two Bars” now restores the previous content of the second bar
Modifying a note from the Virtual Fretboard preserves its attributes
Undoing the modification of a note from the Virtual Fretboard now works correctly in one step
Fixes the score cursor position after undoing a paste on the last beat
Fixes ties after pasting on multiple bars
Fixes the audio preview of Mordents and Turns
Fixes setting Stems Direction on a selection containing grace notes
Fixes the behavior of the score cursor when clicking on a bent note
Fixes an input error when typing fast in the tablature view
Engraving
Adjusts the slash notehead anchors with the “AMJazz” font
The tempo unit is now correctly taken into account for “rall” and “accel” indications
For minor keys, “1=” is replaced by “6=” in Numbered Notation
Fixes collisions between the “Repeat two Bars” mark and some bar header elements
Fixes the placement of a Bend Release in Standard Notation
Fixes some attributes (HO/PO, ties) of notes bordering a selection after a transposition
Fixes the alignment of diagrams between themselves
Ties between distant slash notes are now correctly displayed
Interface
Notifications on the Welcome page can now be permanently disabled in the Preferences
VU meters in the Drumkit settings popup are now linked to the active sound
Undo is now correctly available on the first action in the Pedalboard and on volume change
Updating the track name now correctly updates the corresponding entry in the “Track” menu
The palette is now correctly updated after tying a beat
The track name in the inspector is no longer selected when double-clicking on the Global View track during playback
The “Add Track” button in the Global View is now correctly disabled during playback
Fixes some cases where the license had to be entered twice
Fixes the movement of the cursor in the Global View bar header when changing tracks
Fixes the Preferences dialog size in case of an unusually long stylesheet name
Fixes empty score info fields when opening a custom template
Fixes some errors in the Time Signature dialog regarding beamings for 16th and 32nd notes
Selections starting with a grace note are now displayed correctly
The tempo in the LCD is now correctly updated when changing the relative tempo
Fixes some translations
Import / Export
MusicXML
Correctly imports the fingering including for a keyboard track
Dynamics are no longer exported in the middle of a chord
MIDI
Fixes the playback after pasting a MIDI file in Guitar Pro
Fixes the import and paste of MIDI files containing consecutive notes with the same pitch
Imports empty MIDI files
Imports the correct amount of bars when the last one is not complete
Audio
Audio export now automatically adds a file extension
Graphique
Fixes how the current time is fetched and formatted for the graphic exports
Audio Track
The cursor movement is now correctly clamped to the bar’s duration
Fixes the visual feedback on hovering the audio track bar and beat lines
Feels are now correctly mapped onto the audio track
The voice index is now correctly preserved when moving the cursor from the audio track
Fixes the zooming behavior
While repitching, the audio track now stays synchronized
Fixes the behavior of the “Add bars” (+) button when the audio track does not have the focus
mySongBook
Reopening the Free Tab of the Day no longer requires to log into mySongBook again
Improves the design of the Expired Trial dialog to highlight the possibility to continue with mySongBook
Miscellaneous
Overall improvement of the handling of audio devices
Fixes the registry key edition for the soundbanks installer (Windows)
Crashes
Fixes a crash on opening a file containing wrong tags
Fixes a crash on refreshing the audio devices in the Preferences dialog
Fixes a crash on adding a note on an empty selection using the MIDI Capture or the Keyboard View
Fixes a crash on adding notes preceded by a Sustain Pedal
Fixes a crash on switching from Grand staff to Single staff with an active selection on the lower staff
PSP 608MD status?
I just went to the PSP site thinking I'd find an update to 608 Multi-Delay, but it's still at last year's v 1.8.0.
I'm kind of surprised they haven't fixed that one yet. Any one know anything on that?
Re: PSP 608MD status?
stubbsonic wrote: Thu Apr 11, 2024 8:39 am I just went to the PSP site thinking I'd find an update to 608 Multi-Delay, but it's still at last year's v 1.8.0.
Nope, nor have they responded to my support request. The VST2 and VST3 work but not the AU.
mikehalloran wrote: Thu Apr 11, 2024 10:11 am ... The VST2 and VST3 work but not the AU.
Ah, that's good to know. Thanks!
I'm able to load the VST2/3 in DP, and was able to use the AU of Blue Cat's Patchwork to load the VST3 in Mainstage, so I'm all set.
Vienna Synchron Player updated from v. 1.3.1242 to 1.3.1263
Run Vienna Assistant to update.
Version 1.3.1263 - April 11th, 2024
Added
- Vienna Power House Support
Fixed
- Crash when scanning volumes with broken permissions/access
- When reloading a previously selected humanize preset that preset was empty
New UVI Portal 3 updated
So I launched UVI Portal to check on any UVI updates and got a dialog telling me there was a new "Portal 3" and to click the link to update. For whatever reason, it took me a French language version of the site. So you can just go here and get it if you dont parlez-vous français.
https://www.uvi.net/download-with-portal
UJAM Virtual Guitaist Silk2 and Amber2 updated to 2.3.0
Got an email about both of these being updated. Just before you run the UJAM Portal/Downloader, launch DP and open the plugins and make sure that you're signed in and they are activated. For some reason I was signed out and the updater wouldn't let me download and install the updates.
Below is what was stated in the mail. Don't know what they're talking about when they say Apple Silicon compatibility. The previous versions were already, but who knows?
Virtual Guitarist Update
We have just released an update to Virtual Guitarist that introduces VST3 and Apple Silicon compatibility, improving performance on all devices. AAX Universal Binary support is also now available, ensuring smooth
operation in various DAWs.
Also the updater is a bit wonky. You may updated one and then if you need to update another instrument you'll get some sort of error that the download is unavailable. Quit UJAM (from the menu bar item) and then relaunch it.
Native Instruments Updates
A whole bunch dropped today:
