PluginDoctor updated from 2.2.7 to 2.2.8
2024/01/22: v2.2.8 fixed Hammerstein display errors
https://ddmf.eu/login/
Re: PSP Audioware 2445EMT and PSP42 Updated
stubbsonic wrote: Fri Jan 19, 2024 8:19 am
bayswater wrote: Fri Jan 19, 2024 8:05 am I get emails from them when one of the plugins I have is updated. A little advertising too, sometimes, but not nearly as much as most suppliers.
That's helpful. Will subscribe to PSP now.
I just followed up on an email from PSP about new versions of Impressor and Saturator, and noticed that 6 other plugins had been updated, and I didn't get email about those. Maybe these will come, but looks like whenever there is an email, checking the rest of your PSP plugins is in order.
PSP Updates
Indeed... good reminder. I read something on another forum that PSP has made updates to many of their plugs across the board. I noticed all of them had the fix for resizing and a "full screen" issue with Cubase 13... similar to the changelog I'd seen on their other plugs.
Off to the PSP site now! :)
UPDATE: As also mentioned at another forum, PSP has made the user download area a bit more friendly with a little "New Release" notice next to updated plugins. Every little bit helps. I wonder how long before PSP puts out a dedicated installer/updater app which seems to the the trend these days? I'll have to ask Antoni at NAMM if there are any plans for that.
Re: PSP Updates
James Steele wrote: Tue Jan 23, 2024 11:07 am
I'll be asking the same question.
The little green "New Release" notices are most welcome till then.
Re: PSP Updates
I should be noted that PSP states in the changelog for these latest versions that they are no longer supporting macOS 13 and earlier, so if you're not on Mojave or later, I'm guessing you should not install these latest PSP updates.
Here's the changelog from SpringBox, but it's typical of these newest updated plugs:
PSP SpringBox Algorithmic Reverberator
Version History
**** 1.1.3 ****
09.01.2023
NEW:
- presets
BUGFIXES:
- AudioUnit: resizing problem - fixed
- Cubase 13: plugin opens in the full-screen window - fixed
NO LONGER SUPPORTED:
- macOS 10.13 and earlier versions
Re: PSP Updates
What's interesting is the when you mount the InfiniStrip dmg file, in indicates that it's a beta version. Hmmmm...
Screenshot 2024-01-23 at 11.30.31 AM.png (71.53 KiB) Viewed 1184 times
One cool thing I noticed from the changelog... they added an OldTimer module to the strip.
PSP InfiniStrip version history
14 Jan 2024
PSP InfiniStrip WIND edition
PSP InfiniStrip Mono v.1.3.0
PSP InfiniStrip Stereo v.1.3.0
NEW:
- OldTimer compressor module added - its a module based on the PSP oldTimerME
CHANGES:
- reference for Threshold in the FET Pressor was adjusted to better match other comrpessors, it was shifted by -1.5dB
Vienna Ensemble Pro 7 updated to 7.3.3562
It seems to take a little bit longer to launch than the previous version, but not bad.
Into:
Latest Version:
7.3.3562
Size Download:
348.00 MB
Size Installed:
364.90 MB
Recent Changes:
Build (3562)
Fixed: Auto-Save files were saved with the wrong file extension
Fixed Win: Expanding large folder structures could lead to performance issues
Added: Enhanced crash report system
Arturia Analog Lab Pro updated from 5.9.0.4400 to 5.9.1.4493
Probably applies to other varieties of Analog Lab V as well.
V 5.9.1
Bugfixes
• No more crashes when installing Vintage Lab preset bank
• No more crashes when recalling a session made with SEM V2, CS-80 V3 and Wurli V2
• No more stuck notes when using the sustain
• Sustain assignement in Keyboard Settings now works correctly
• Visualizers are now working correctly on first GUI opening
Re: PSP Updates
mikehalloran wrote: Tue Jan 23, 2024 11:14 am
I did see someone say on another forum that PSP is already working on a unified installer app. Not sure what their source was—they didn't say. But it would seem an obvious move and most welcome. On that subject, I sure wish Plugin Alliance could get their act together and update their app to notify the user of updates. Glaring oversight. I guess PA is now owned by some larger interest right? I want to say it's the same entity that now owns NI and iZotope. Maybe they plan to integrate all the products into Native Access eventually?
Yea, there are definitely some drawbacks to these plugin managers, not least of which is you can't save the installer and use it if the new version doesn't work.
Plugin Alliance should change the name of their app from PA-InstallationManager (I forget to look for "PA") maybe they could call it, Plugin Alliance Install Tool
Re: PSP Updates
James Steele wrote: Tue Jan 23, 2024 12:11 pm
Correct.
That's my guess, too.
Re: PSP Updates
James Steele wrote: Tue Jan 23, 2024 11:07 am Indeed... good reminder. I read something on another forum that PSP has made updates to many of their plugs across the board. I noticed all of them had the fix for resizing and a "full screen" issue with Cubase 13... similar to the changelog I'd seen on their other plugs.
A while ago, you could build an installer of all the plugins you bought. I suppose that got busted up when they started to move to iLok.
Michael Stewart
Post by Michael Stewart »
Izotope RX 10 standard, updated to 10.5.0, now available though the portal.
Re: iZotope RX 10 Advanced Known Bug - Revert to 10.4 is the Fix
HCMarkus wrote: Fri Jan 19, 2024 4:45 pm
This is a bug with RX 10.4.1 and 10.4.2.
Please revert back to RX 10.4.0 for now until the RX 10.5.0 patch comes out.
Sorry for the inconvenience with the sample rate mismatch.
iZotope has released 10.5 version of RX10. Thanks for the heads up James!
https://www.izotope.com/en/products/downloads.html
HCMarkus wrote: Tue Jan 23, 2024 2:06 pm
Yep... I also posted to this topic yesterday: :D
viewtopic.php?p=608632#p608632
