Stylus RMX with Reason files
I was wondering if it is possible to use the Dr.Rex loops from Reason in Stylus RMX (via the SAGE converter). The SAGE converter works with REX files, but I can't seem to find the files that are in Reason. Thanks for your help.
- philbrown
Re: Stylus RMX with Reason files
I have not found a way to do that if they are in a Refill. I believe Refill files are created in such a way to not let you have that kind of access to the loops and samples.andymcafee wrote:I was wondering if it is possible to use the Dr.Rex loops from Reason in Stylus RMX (via the SAGE converter). The SAGE converter works with REX files, but I can't seem to find the files that are in Reason. Thanks for your help.
there's a long workaround to record them as audio into DP and reslice them in Recycle...
Just for the record other Rex files (not in Refills) convert and work just fine in RMX as long as you follow Spectra's instructions.
