OK
I finish my music project and now want to send the file to video editor ( I will upload to youtube )
I need to export my music in wave format as I will be adding it to my video in my video software
Do I need to use bounce to disk or export ?
After finishing bounce or export?
- Primary DAW OS: Windows
Thanks in advance
Re: After finishing bounce or export?
Bounce - chapter 84 in the DP user guide.
Edit: I saw in another thread you appear to be using P Lite, so chapter 64 in that guide.
Thanks it seems I have to do a lot of readings
Look how many files created
All I needed was the final wave file
Thanks in advance
You'll find the result of any Bounce to Disk in the Bounces folder. Nothing else is stored there.harmonicaman wrote: ↑Fri Feb 11, 2022 8:42 amThanks it seems I have to do a lot of readings![]()
Look how many files created![]()
DP creates those other folders during the course of your Project. Only Bounces is created during BTD.
In my current church work, I create guide tracks for my singers and players this generates any from 2–20 bounces. Afterward, I rename the folder as Used Tracks which I then use to store all the uploaded tracks I receive — after I've loaded them into DP. When done, I BTD as before but this creates a new Bounces folder containing my final mixes (2–5 depending). It's an organizational thing but it helps a lot and saves time.
