Track color SHADES not showing up in Tracks window
shelly_the_turtle
Re: Track color SHADES not showing up in Tracks window
Post by shelly_the_turtle »
Unfortunately, this still did not work for me. I noticed that other Color Schemes seems to offer shading of colors... but in THAT scenario, the colors of the MIDI regions in Tracks Overview do not match the colors icons on corresponding MIDI tracks. This is so strange!
Try starting a new project. Then follow these steps exactly:
1. Go to Preferences/Track Colors
2. Click Open beside "edit color schemes".
3. From list choose (New) Rainbow, then click Edit, to open editor, then OK.
Just wanted to make sure you did that extra edit step.
shelly_the_turtle
Yeah I did exactly that and it didn't fix it. Starting to feel hopeless haha.
TLT (TechLink Time)
Talk to MOTU support. They might be able to suss out what broke and why.
jroo2790
Post by jroo2790 »
hey I had this problem too and ended up contacting MOTU to fix it. All I had to do was turn down the Background Saturation under "Soundbite Colors" in the Track Colors pane of Preferences. Hope that helps!
jroo2790 wrote: Tue Nov 23, 2021 12:19 pm hey I had this problem too and ended up contacting MOTU to fix it. All I had to do was turn down the Background Saturation under "Soundbite Colors" in the Track Colors pane of Preferences. Hope that helps!
Thanks for checking in with this!
rkriviera
Post by rkriviera »
jroo2790 wrote: Tue Nov 23, 2021 12:19 pm All I had to do was turn down the Background Saturation under "Soundbite Colors" in the Track Colors pane of Preferences. Hope that helps!
Oh man! Thanks a lot! I have been having this problem too, and I've been trying to figure it out on my own off and on for a year. What a relief!
stringtheory
Post by stringtheory »
Oh my, just saw this...thank you!
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
garyv
Post by garyv »
HERE's THE SOLUTION...
In the attached labeled screenshot:
  • Open the DP preferences and Select "Track Colors" (#1)
  • Open "Edit Color Schemes" (#2)
  • Double click to edit the color scheme (#3). Clicking on each will change your colors onscreen, so you can click 'til you find the one closest to the one you like or the "Theme" you're using.
    Don't be confused...
    "Schemes" are basic preset color sets MOTU gives you. "Themes" are presets (provided by MOTU or customized by you) containing a bunch of pre-configured settings and "Color Schemes". Sometimes the scheme just wasn't made with gradients, but they can all be modified.
NOW, here's where MOTU screwed up (aside from confusing us with "Themes" and "Schemes")... Themes without gradients aren't "broken" as we thought, there's simply no intuitive indication onscreen that the "Color Scheme Editor" is a modifiable gradient spectrum tool. This is where you can easily customize the "Scheme:"
  • Double-click on the first color box (#4) where you want the spectrum to begin and change it
  • Do the same with the 8th box (#5)
  • Click "OK," "Done," "OK..."
One last trick for the "spectrum" lines: You can actually drag the rightmost color box to the left (#5 to #4) or vice-versa to reverse the gradient order.
Screen Shot 2023-08-07 at 1.18.40 AM.png (635.92 KiB) Viewed 694 times
Nice first post, garyv. Thanks!
I note you effectively used the font color tool available here at MOTUNation, too!
