Recommendations on a multi-delay plugin
Prime Mover
Post by Prime Mover »
I have use for a versatile delay plugin where I can create many discrete delay lines at different intervals. I often have need for modeling outdoor environments, and would like to algorithmically model things like canyons and hillsides, which typically have a number of individual reflections. I was hoping FabFilter might have something in their bag of tricks, since I like their workflow of being able to create as many different "nodes" as you need. But unfortunately they don't really have anything designed for that.
Outdoor spatialization is pretty niche since most music is recorded with MORE reflections to start with than outside environments. I'm often working with outside recordings anyway, and fairly close-up ones that are dead dry. I could just find some IR packs, but delays are great for outdoor reflections, so I'm looking for a product that would be ideal for this kind of work.
EDIT: A quick look around revealed "The Slapper (stereo)" by CargoCult, which looks good, anyone have any experience with it, or any other related suggestions?
— Eric Barker
Eel House
Re: Recommendations on a multi-delay plugin
Hey Eric,
I suggested UVI's Relayer here a few years ago. It's super-impressive in its ability to let you tweak individual taps; I'm just not 100% sure that you can specify discreet intervals.
A cheaper and possibly more-appropriate option might be PSP's 608 MultiDelay. Each tap has selectable feedback, stereo image & position, delay time, multimode filter, modulation, drive/tape saturation & reverb.
HTH, mate.
Prime Mover
Yeah, the one thing I notice is that most of these have a universal feedback interval. You can specify initial delay time, but all delays subsiquently get repeated by a global time. I'd be more interested in just a set of parallel delays that feedback by their own delay time, maybe with some X-Feedback to other delay lines. The feels like it should be pretty simple to setup, I'm half tempted to just mock it up in Reaktor, but god that workflow drives me nuts, it would take me hours to jump back into it. Slapper looks like it could.
For now, the project at hand is done, I used KORG's MDE effects unit which gives me 4 pannable delay lines, like a stripped down version of Waves Supertap. For the particular job at hand, I found it wasn't too critical. But I want to keep my eyes open, because these projects fly by every so often, and I can budget for something.
Currently "Slapper" looks the closest for my field recording work.
Tho, while I was looking around, Valhalla Delay sounds GORGEOUS for music, at $50 I may nab it up, off the clock. It won't do me any good for sound design work, but sounds killer on synth leads. I love Valhalla's plugs, "Room" appears on almost all my projects.
— Eric Barker
Eel House
Phil O
Post by Phil O »
Prime Mover wrote:Yeah, the one thing I notice is that most of these have a universal feedback interval. You can specify initial delay time, but all delays subsiquently get repeated by a global time.
Yeah, this is what I've seen. If you find you're stuck with the multiple instance route, don't forget about DP's echo plugin. When I need a no frills, simple single delay it's my go-to. I can imagine that would be a PIA, though, if you need many instances. :?
Melda makes TurboDelayMB. It's got all sorts of configurations (kind of overwhelming at first) but a couple of them have multiple delays with independent feedback. It was about 60 bucks if I recall correctly.
I'm not familiar with MM's suggestion. I'll have to check it out.
I have PSP 608 and it is very versatile. I don't use delays much (should I admit that?)
I remember with DP's delay I have to use it in a aux send (and not as an insert) because the wet/dry resolution is too course. Too much or too little.
I, too, have 608 but from your description, it looks like Eventide’s H3000 Band Delays might just be the ticket. Not only can you can tweak the individual delay times but filter them for eq and band pass. $199 and you can request a demo.
https://www.eventideaudio.com/products/ ... and-delays
I picked this up a few years ago as part of a bundle but have never used it.
Features
8 voices, each of which can be altered by frequency, resonance, filter type, delay time, volume and panning.
Filters assignable as band pass, low pass, high pass, all pass or notch filter.
Assign the H3000 Function Generator to several parameters to create movement and bring life to drums and stringed instruments.
Beat grid gives visual representation for creating unique rhythms from your sound.
Route a MIDI keyboard to the plugin to play the filters as musical notes.
Includes presets from original H3000 hardware in addition to many new inspiring choices.
MixLock keeps the wet/dry mix of the effect static as you scroll through presets or user-defined snapshots
Prime Mover
DPs delays are good but both (Echo and Delay) are limited. Echo has no stereo control: what goes in comes out with no stereo repositioning. It's like SuperTap without panning controls. Delay is more like a twin delay pedal: it's dual-mono with X-feed. Neither one is particularly great for my needs. TBH: I feel underwhelmed by both of these, even for musical projects. They come across as too fiddly, yet too basic at the same time. I don't have very many high-end delay plugs, but the ones inside GuitarRig usually give me more immediately interesting results if I'm being creative, and I'm not going to pretend those are anything particularly special. Their new Analog Delay pedal plugin has never grabbed me. Sometimes "one nob" plugs sound killer on everything, that one doesn't.
I'll check out your suggestions.
— Eric Barker
Eel House
Prime Mover
BTW, this banner on Valhalla's site is TOTALLY selling me on their delay plug:
— Eric Barker
Eel House
:lol:
Phil O
Post by Phil O »
Funny. I haven't seen that before. I have used the ducking feature on female vocal. Worked remarkably well for pulling it forward in the mix. Just like the duck's bill is forward in that photo.
mhschmieder
Post by mhschmieder »
PSP's 608 Multi-Delay is ancient but does the job and did get a major upgrade as I recall. I haven't used it in a while so can't remember if it was one of the ones that was re-done on a later release.
I have a gazillion delay plug-ins, but unfortunately I did not document which ones support multi-delay, as it isn't of particular interest to me, so it would take too long for me to go through them all. Looking at my list right now, none stick out by their product names as being obvious candidates.
mesayre
Post by mesayre »
What about d16 Sigmund?
It's only 4 delay lines, but they are fully independent, including the feedback I believe. You also get a drive circuit, filtering, and some decent modulation capabilities:
https://d16.pl/sigmund/overview
DP 10 - Win 10 - Ultralite AVB
The installer images for the 3 PSP plugs I have (608, Lotary, and PnoVerb) are all dated Mar. 7, 2020.
The installer package for the 608 is dated May of 2019. Lotary is Jan of 2020, PnoVerb is Oct of 2019.
Yeah, the oldest still-supported plugins should be last year IIRC, when PSP made them Catalina-compatible.
