Ultralite mk3 hybrid v 1.07
Angthekeys
Post by Angthekeys »
Hi everybody,
My system:
- ultralite mk3 hybrid.
- macbook pro, os sierra 10.13.2
- logic 10.3.3. at moment connected through usb
- driver 1.6 71459 downloaded from the website page dedicated to sierra.
Many issues, for first, step by step, trying to solve...
if anybody share similar system, following the manual, i can’t find follwng
Files/ applications after the download:
Dp, firewire audiodriver, motu MIDI driver, audiodesk 3.21 downloaded but not working.
I’m using logic, and sw above are not a priority to me, but i’m having some problem also with cuemix, so’ for first i don’t understand if previous sw are not included in last update, manual it’s dated 2014.
Than i’ll post others problems if i won’t find a solution. Thks
Macbook pro 2015, 2,7 ghz, 8gb, motu ultralite mk3 hybrid, logic pro 10.4
Keys: vsynthgt, jdxa, system8,fp4f, vr09,fa06, masterkeys akai,maudio, mixer yamaha mg6,10, behr1204fx
Re: Ultralite mk3 hybrid v 1.07
The firmware log shows 1.07 as the latest firmware so you're good there.
v1.6.73220 is the latest driver—you're on High Sierra. 10.13.3 is the latest OS and 10.4 is the latest version of Logic Pro as of a few days ago. Since you are running an old driver and both the OS and app have had recent updates and bug fixes, I'd start there.
In addition, you've not told us what the issue is. If you still have one after becoming current, please be specific so that we have a clue.
Angthekeys
Hi mike, thks for answering,
for first i would like to know if all the drivers and application reported at page 30 of the operation manual:dp, firewire, MIDI drivers, should have been downloaded by the installation cd (2014) or frm the sierra update because in my case there aren’t. Audiodesk 3.21 doesn’t start. So’ i thought that something in drivers doesn’t work. Maybe i’m wrong but..
My first issues..
Ex 1: logic project already saved, with multitrack. If i send one track to output3, output 3 in logic don’t receive any signal, i’ tried all the output and the signal showed in output 5?!?..they don’t catch with each others
Ex 2: motu cuemix, no effect from equalizer, compressor limiter, input, output, so’ no dsp :-(((
In general i expected more automatization between the two systems.
Did you upgrde logic at 10.4? I’m having some problem now, don’t think logic upgraded to 10.4 due to motu issue... don’t you? Thks for help
Start with the drivers.
Drivers on the CD are rarely up to date. It doesn't matter the hardware or the vendor. For that reason, most hardware vendors give you links and ask you to download everything these days. The latest drivers are listed here:
http://motu.com/techsupport/technotes/driverlog/view
Angthekeys
Hi mike,
Thks again, logic 10.4, driver 1.673220, sierra 10.13.3 downloaded,
i'm testing all options, first issue, after first downloading cumix disappeared from the computer, than i repeated procedure and now it shows, but again the dsp doesn't works. already wrote to motu opening a tkt, if you, or others users have some idea, i'll chk. thks ang.
The Spanier
Post by The Spanier »
Update: I don’t know how, bu it started workin. The fact is that I can’t gent any sample rate higher than 44kh. If I switch to 96kh or higher it forces back to 44kh. Any thoughts??
terrybritton
Post by terrybritton »
The Spanier wrote:Update: I don’t know how, bu it started workin. The fact is that I can’t gent any sample rate higher than 44kh. If I switch to 96kh or higher it forces back to 44kh. Any thoughts??
Where are you performing the switch to a different sample rate? On mine, I need to use the MOTU Audio Console app for that operation.
Terry
MOTU 828 mk3 hybrid
