Which Windows Laptop Should I get?
compositor
Post by compositor »
I want to buy a powerful Windows 10 laptop for using DP. What laptop brand/specifications would you recommend? I am not a gamer, but how would a gaming laptop do for DP? They are really good for graphics & 3D, but I wonder how it would work for editing audio?
Re: Which Windows Laptop Should I get?
You don't need the super graphics of a high performance gaming machine but a decent card is a plus. Most can handle a 2nd monitor when you're editing in your studio.
Otherwise, you want a good amount of RAM (at least 16G but 32G isn't too much), an i7 Quad and a 2T SSD is nice. These are the same things you want in a Mac for DP.
DP makes use of the floating point processor in the i7. I've A/B'd against i5 machines and it makes a noticeable difference.
mesayre
Post by mesayre »
I have been running DP on an ASUS gaming laptop for about 5 years now, and it's worked out pretty well. It's got some cheesy branding, but the performance has been great. At the time I got it, it was more or less top-of-the-line, and for about half the cost of a similarly spec'd mac. ASUS supplies a lot of the components that other makers use, so you're getting the same stuff in the box.
But it hasn't been without some headaches. It took a while to get my graphics card dialed in - its an nVidia card. Since gamers want maximum framerate at almost any cost, these things are often set up to give deference to the GPU. This can result in sky-high DPC latency that will cause audio dropouts at lower buffers. This can be optimized by tweaking settings on the card, but I'd recommend doing some research on DPC latency of the graphics card of the specific model you're considering. The other thing with GPUs - the fan. The noise from the fan is atrocious, and since it's a laptop it will always be a foot from your face. Another thing to google for your model.
FWIW, I can't know why you want a laptop, but I'm actually going the other way. This laptop is getting long in the tooth, and I'm planning to replace it with a desktop system. The laptop has left my studio about once a year. Not worth the tradeoff in power, price and future upgrades. I may pick up a cheap little laptop so I could do easy edits and such on the go, but I basically can't work without all the other junk in my studio anyway. Something to consider, if you haven't already.
DP 10 - Win 10 - Ultralite AVB
rizoaudio
Post by rizoaudio »
mikehalloran wrote: DP makes use of the floating point processor in the i7. I've A/B'd against i5 machines and it makes a noticeable difference.
Thanks for tip. I think I'll also go for a quad core i7 with about 16 GB of RAM. But I've noted these high end Windows laptops are close in price to the 15 inch MacBook Pro. Should I save some more and just buy the Mac?
manual coffee grinders on Kitchen Lola blog
This forum prohibits posts concerning religion. :wink:
As long time Mac guy, I can advise that it seems things may be a tad more plug-n-play in the Mac ecosystem. That said, as a long time Mac guy, I haven't tried setting up a PC DAW.
HC Markus
https://rbohemia.com
