MX4 works with DP8.06, Mavericks 10.9.3 and 32 Lives 1.0.4!!
There was another post on the board in the MX4 forum where someone got it working with 32 Lives v.1.0.3 in Mountain Lion. It was at the tail end of a topic so just in case anybody missed it... thought I'd share the big news! MX4 is now viable in DP 8.06, Mavericks 10.9.3 and 32 Lives 1.0.4!!
There is still a little graphic glitch wherein the DP VI Window doesn't come to front, but you can cycle through DP's open windows to get it back and close the VI window. See QuickTime movie below:
- KarlSutton
Re: MX4 works with DP8.06, Mavericks 10.9.3 and 32 Lives 1.0
So it $99 to use MX4 - what other 32bit would this fix?
I don't think I miss MX4 enough to justify the expense.
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
Quite a few 32bit AUs, actually. There are multiple threads on 32Lives.So it $99 to use MX4 - what other 32bit would this fix?
The YMMV principle applies. 32 Lives allows me to continue to use my Liquid Mix, Slate FG-X, MX-4 and even the original Plugsound Pro (whose library I could use in MachFive 3, but I enjoy the PSP3 interface).KarlSutton wrote:So it $99 to use MX4 - what other 32bit would this fix?.
James, thanks for pointing this out. I upgraded to a new mac pro and DP8 and have been slowly getting new updates for 64 bit. I'm demoing 32 Lives and tons of my old 32 bit plugs are working again. This includes Symphonic Instrument. I might even try it with Mach 5 2.James Steele wrote:The YMMV principle applies. 32 Lives allows me to continue to use my Liquid Mix, Slate FG-X, MX-4 and even the original Plugsound Pro (whose library I could use in MachFive 3, but I enjoy the PSP3 interface).KarlSutton wrote:So it $99 to use MX4 - what other 32bit would this fix?.
Problem is MX4 isn't opening. It hangs and I have to force quit DP. Every other plug and software seems fine. Did this happen to you too? I downloaded latest version of MX4 but still getting the pinwheel of death. Curious as to what you did to get it to open.
Thank you!!
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
I'm not sure. I'm not at my studio. I'll have to check into it.
What OS are you using?gongbass wrote:Problem is MX4 isn't opening. It hangs and I have to force quit DP. Every other plug and software seems fine. Did this happen to you too? I downloaded latest version of MX4 but still getting the pinwheel of death. Curious as to what you did to get it to open.
