Playback Bar/ Audio Performance
Hello,
I just got of the phone with Motu & they are even stummped???
No matter if i playback 1 track or 30 tracks of audio my playback bar in the audio performance window is pegged 1/2 way?????
What we have done:
System priority tab is set to high in the preferences, I have repaired disk permissions, different buffer settings/ studio setiings cappachino/ caforama ect...Logging on as a different user/account still no luck!!!
Any answers to this???
Thanx
Donnie
www.musicdragon.com
www.myspace.com/dragonmusic
2408 mk III G5 dual 2gh with 1 gig of ram...
What we have done:
Thanx
Donnie
www.musicdragon.com
DP 4.6, Panther 10.3.9, G5 dual 2.0, 2408 MK II & III, Reason, Korg Triton Studio 88, Genelec Monitors, Blue mics, Presonus MP20 pres (upgrading soon:)
check out the band www.musicdragon.com or www.myspace.com/dragonmusic
- sdfalk
When you say they where stumped, what exactly did they say?
My playback meter is pegged at half way as well, but what of it?
Everything else performs perfectly fine.
A Metric Halo ULN8-3D…mmmmmmm
Thanx for the reply
(When you say they where stumped, what exactly did they say?)
They had me set the System priority tab to high in the preferences, Repair disk permissions, different buffer settings/ studio setiings cappachino/ caforama ect...Logging on as a different user/account...
They said certain systems have been experiencing this & that if I notice any other problems to give them a call. (If you change your studio settings to "0" on your allowed tracks watch your audio performance bar keep raising
(My playback meter is pegged at half way as well, but what of it? Everything else performs perfectly fine.)
Exactly, my meter is pegged 1/2 way too & also running fine. I just got everything going with the new G5 424 card and didn't want to have my band come over, get all set up & start having issues....
I just thought maybe someone on here might have a fix or some insight on it?
Donnie
Donnie
- croyal
You should want the playback buffer to fill at least hallfway- which means RAM is being filled to help keep everything in sync and sounding good. As long as no spikes and it sounds good...
Diff than the CPU bar (top bar) filling halfway with no VIs, plugs or anything. That's what happens with DP4 on a pre-G3 machine with 128 mb RAM, no audio tracks and sitting still---indicating a woefully underpowered box for DP4.
Chris
Chris
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
Very Cool, thank you:)
Good to know about the (cpu) bar thanx Chris
motu said the same thing:)
Other than that everything is stable (no peaks unless I limit to much,hehehehe & 30 tracks with plugs on a dual g5 1 gig of ram is barely scartching the cpu bar
Can't wait till I can put 2 more gigs of RAM in for some native instruments & waves
Donnie
Donnie
- yofo
Before I upgraded to 4.5 the playback bar was usefull. It let me know if I started playback to soon. If I waited a couple of seconds it would slightly fill but if I started to soon it would half fill solid. I was alarmed at first after I upgraded , I didn't know why it was different . Now I just don't look at it .
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
Count me in....
MBP i5/i7, MacOS 10.13/10.15, MOTU DP 11, Traveller, Track 16.
Dual 867Mhz G4 (MDD), APPLE 17" Display, MacOS 10.4.11, 2Gb. RAM, 4 internal drives (2 x 120 gbs./8mb cache audio drives in ATA66 bus, RAID stripe), MOTU 896HD, 4 x UAD-1, WaveArts Wavesurround Pro, DP 5.13, Reason 3.0.5, Recycle 2.1, Novation Remote 25SL, Mackie HR624, MGE ups.
