Is DP 32 bit floating point?
Armageddon
Re: Is DP 32 bit floating point?
Post by Armageddon »
Phil O wrote:Glad you got that worked out. Now you're back to the debate about whether or not it's worth it. I don't really KNOW if it makes an audible difference, but it can't hurt. I've recently been struggling with the idea of going 96K. But that's for another thread. Good luck!
I've been doing all my film work at 96 kHz/24-bit in DP, then doing a downgrade to 48 kHz/16-bit (which seems to be the norm, since all HD projects appear to be doing their audio in that sample depth/bit-rate) at the mastering stage in Wave Editor. The main reason I do this is for future-proofing the scores, in case there's a higher-fidelity format in the future that needs it. Now, do I really hear a difference? Not really, though the files are significantly larger and there seems to be a bit more headroom. It's not like the jump from 16-bit to 24-bit, where you suddenly hear twice as many details as you did in 16.
I do plan on remastering my album at 88.2 kHz/24-bit and mixing at 32-bit float.
daniel.sneed
Post by daniel.sneed »
HCMarkus wrote:Shooshie, if you've read any of my posts over the years, you know I base my decisions on rumor, speculation, and irrational exuberance, not to mention the heft and cost of speaker cables and volume control knobs. [...]
Markus, as kids, could we have been in the same school?
