BeatPadMan wrote:
Hey still wondering if anyone is having problems with 1.5 showing the BPMSA 1 OUTPUT and the BPM SAMPLER 1 in the SAMPLING slot? Now, BPM 1.5 isn't showing either, after only having BPMSA 1 OUTPUT. Also, when I hit the CLIP button next to the SAMPLING button and the CLIP VIEW opens. Then, I DRAG & DROP a WAV file into the area. Next I turn on the SLICE and the WAV file is sliced
Hit the Transport 'Record' button... it's magical...monogee wrote:
I'm having the same problem here. Sampling options not showing up. All I get is, "No Choices."
EDIT: Let me correct this... Hit Transport Record, Sampling Record, Stop, then Undo. :::insert smiley here >
All jesting aside...this appears to be related to the 'No Undo function, unless Record is clicked first' issue
