New no Brainer- anyone using Toontrack Drum Tracker
- Kellog
Hers a link to an audiomidi.com no brainer for Toontrack Drumtracker drum replacer. Is it any good?
http://www.audiomidienews.com/audiomidi ... off-j.html" onclick="window.open(this.href);return false;
Mac mini (2018) 3.2 Ghz 6 Core Intel Core i7 w/64 GB ram, OSX Catalina 10.15.7, DP 10.13, UAD Apollo Quad, Komplete 13 Ultimate, Superior Drummer 3, EZ Keys, EZ Bass, EZ Mix 2, Stylus RMX 1.7f, Avid Eleven Rack.
Re: New no Brainer- anyone using Toontrack Drum Tracker
I just got it, so we'll see.. it appears to operate in stand-alone mode only. Too bad, I thought it would be a plug-in for DP. Oh well, if it works, it will still be worth the 20 bucks.
Please let us know, reading some interweb comments it does seem to be not a transparent in it's use as they would like you to think.
I use it, and it works great. I use it routinely to replace badly tracked drums. Thumbs up!
- KEVORKIAN
+1pcm wrote:I use it, and it works great. I use it routinely to replace badly tracked drums. Thumbs up!
It's the most accurate solution for replacing drum tracks that I've found. I think it's simple to use... you just import your raw tracks into Drumtracker, let DT analyze the files and perfect any missed timings by adding or dragging the lines.
Slate's Trigger is very close though (and is realtime), however, I like that you can edit the timing of the MIDI notes in Drumtracker. I find that I do very little editing of the timing because of this.
The workflow is more akin to Melodyne in that you have to view Drumtracker as an external editor.
- Kellog
Great feedback, thanks!
I find it to be great. I did have a small issue with the mapping, but it seemed to do what it promised very nicley. I mean, for $20??? How could you go wrong.
i have to try mapping it to my EZ Drummer. May work better that way.
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
- Larry Mal
I bought it. Haven't used it at all, and it largely duplicates functionality that I already have in Logic, but I thought it might do it better. For $20, I'm willing to find out.
It's a good looking bit of software, I will say that for it.
Mac Pro 2X2.8 GHz 8 Core, Macbook Pro 2.16 GHz Core 2 Duo, 2 GB's of RAM. Logic Pro 8. Digital Performer 5.13. Pro Tools M-Powered 7.4. Ableton Live 5. Focusrite Sapphire Pro 10 I/O interface.
