After installing 10.5.7 I couldn't get certain older projects created in 5.13 to open. Many error messages about problems reading from the disk as well as disappearing mixer on some that would open before crashing. What was odd was that other projects created at the same time opened just fine. LSS-I trashed DP Preferences and AU Info Cache, repaired Permissions, and rebooted. As DP opened, I skipped all NI plugins. This fixed the problem with all the busted projects.
NI plugs skipped were KPlayer 2, Kore 2.04, and FM8. I think FM8 is the main culprit and will add the others as I need them.
Hope this helps some folks.
OS X 10.5.7 & DP 5.13 Solution?
2.16 Ghz Intel iMac 2GB OSX 10.5.7 DP 5.13
- Mr. Quimper
Re: OS X 10.5.7 & DP 5.13 Solution?
I've also had some issues w/ my NI products and 5.7 with a clean reformat/install of all the latest updates....
2.5Ghz Quad-Core/20GB DDR3/10.11.6/DP 9.5
