MIDI Stuck Notes... Is this the solution?
dougieb
Post by dougieb »
I had my MTP II plugged into a USB hub - actually my Apple monitor (30" of love ;-))
MOTU tech support suggested that I plug it direct to the tower - then I moved something else to the hub in the monitor.
So far... so good... I have to test more tonight, but does this solve anyone else's problems?
- dougieb
chrispick
Re: MIDI Stuck Notes... Is this the solution?
Post by chrispick »
I'm curious: Are most of you who are having MIDI problems linked via USB? How many of you use Firewire for MIDI?
I found USB on Macs and PCs to be temperamental ports, especially when things like dongles are added to the equation.
I run my MIDI via firewire and it's rock-solid. Never a hiccup. Not saying that to be smug or anything -- just wonder if the USB variable has been considered.
Rush909
Post by Rush909 »
my MTP USB has always been solid until moving to the OSX/DP4.5 combo... then all hell broke lose...
to get around the problem I have been using USB direct from my Yamah Motif and it has been rock solid... good thing is that my motif is the only module I still use externally...
moving MTP AV USB connection from HUB to tower improved things, but did not fix the problem...
r.
Bruce
Post by Bruce »
I also tried moving my USB connection from the hub directly to my computer-no differecne for me.
BTW- It was a very surreal and frustrating experience to read the glowing review of DP4.5 in the latest Electronic Musician while all these problems are going on. Boy wouldn't it have been a kick in the pants if the reviewer has experienced all the stuck note issues and reported them in the magazine. Now THAT would have gotten the problem solved!
Bruce Zimmerman
Sound Productions/ZimMusic Library
MacPro 3.3 6 core, Yosemite/Lion, DP 8, MTPAV, MOTU 828mkIII, Spectrasonics VIs, Ivory 2, Mach V2 3, Vienna, Ethno 2, Lots of Play VIs, etc
In your eyes, the light, the heat
